Page 23 of 99 FirstFirst ... 13212223242533 ... LastLast
  1. Posts : 72,052
       #220
    barbarossa2241 said:
    I did create short cut and did a scan. "found corrupted file but not able to fix some of them". What do I need to do now ? Thanks.
    Hello Barbarossa, and welcome to Seven Forums.
    If you could create the sfcdetails.txt file from OPTION THREE in this tutorial, then upload it here, I'll be happy to take a look at it to see what SFC was not able to fix for you. :)
  2. Posts : 150
    windows 7 home premium 64bit
       #221
    OK. Let's see if I can find the file report.
    Hm, can't find the report
  3. Posts : 72,052
       #222
    Did you do OPTION THREE in this tutorial on the first page to create the sfcdetails.txt file?
  4. Posts : 150
       #223
    Thank you. I got the report on desktop. I'll try to post it.
    File is attached. Hope I did this right.
    SFC /SCANNOW Command - System File Checker Attached Files
  5. Posts : 72,052
       #224
    Barbarossa,
    The files that SFC was not able to repair appear to be from either a Simplified-Chinese language pack or keyboard input language that you may have added or installed.
    If you are not having any issues with it, then I would not worry about it. If you are having issues with it, then you could try uninstalling or removing it, then installing or adding it back.
  6. Posts : 150
       #225
    I know the Chinese files. Thanks a lot Brink. Awesome forum. I am finding out how little I knew about Windows and PC in general. I just bought this new Asus N53SV-DH72 which is way better than the 2 HPs I have.
  7. Posts : 72,052
       #226
    You're most welcome Barbarossa. Congratulations on your new laptop. :)
  8. Posts : 150
       #227
    Thank you. One more q please: I created a cd for standalone system sweeper but it does not boot from the cd. Went into bios and change the options already. I must be doing something wrong.
  9. Posts : 72,052
       #228
    That would be a question for a new thread since it's not related to this tutorial.
  10. Posts : 150
       #229
    Right. Thanks Brink.
