Page 24 of 99 FirstFirst ... 14222324252634 ... LastLast
  1. Posts : 76
    Win7 Ultimate x64, Windows 8 Enterprise x64
       #230
    Any suggestions please.
    Windows update error today (Win7 Ultimate).
    Suggested run sfc /scannow.
    Ran it from elevated command prompt, and it stopped after just a few seconds saying no errors found!
    I expected it to run for a few minutes at least.
    Anyone had this before?
  2. Posts : 71,959
       #231
    Hello Paul,
    That is a bit fast for a sfc /scannow run.
    How large is the partition that you have Windows 7 installed on?
    Could you post a screenshot of the CMD window showing all of what it said for this in case there may be something else that stands out?
    Could you also upload a copy of the sfcdetails report from OPTION THREE to see if anything in the log file may say why?
  3. Posts : 76
       #232
    Brink said:
    Hello Paul,
    Hi Brink,
    Hopefully 3 attachments have the details you require.
    The partition is the drive, nothing else on it, I only use it for the OS.
    TIA,
    Paul.
    SFC /SCANNOW Command - System File Checker-maindisk.jpg
    SFC /SCANNOW Command - System File Checker-scannow.jpg
    sfcdetails.txt
  4. Posts : 71,959
       #233
    Yeah, that's to fast. It appears to have been interrupted.
    I would recommend to run disk check on your C: drive to check it. Afterwards run the sfc scan again to see how it does.
    If SFC is still that fast, then you might run the sfc scan at boot instead to see how it does.
  5. Posts : 76
       #234
    Hi again Brink,
    Ran disk check nothing found.
    Ran 'scannow' at boot, and it come back with the same result as before.
    Paul.
  6. Posts : 71,959
       #235
    Hmm, have you ran a sfc /scannow scan recently before this? If so, that could be why it finished faster this time. Otherwise, I'm not sure why it would be finishing so quickly.
  7. Posts : 76
       #236
    No, have not run it for quite some time - can't remember the last time, so not recently.
  8. Posts : 908
    Vista Home Premium x86 SP2
       #237
    Hello!
    Yes, I have seen it before. It is not exactly uncommon. In all previous cases that I have dealt with, it has always been in error. Looking over the CBS.log file showed that SFC did in fact scan very few, or no, files. Often the CBS.log actually showed an error which SFC did not graphically report. In my experience, there are certain errors which SFC cannot recover from. In these cases, it stops part way with a 'Windows Resource Protection could not perform the requested operation' error message. When it finishes too fast, despite claiming success, it often has had one of these fatal errors anyway, if I remember correctly.
    Now, I could take the CBS.log, and see what seems to be going on, but if you ask me, it isn't worth it unless you have a problem. If your computer has a problem, which is why you ran SFC, then I shall take a look, but if all seems well, then you risk more by fiddling.
    Richard
  9. Posts : 16
    Windows 7 64 Premium
       #238
    So i did this Scan 6 times in total. 3 for the system32 and 3 for the 64.
    This is the log and i hope you can help me. Thanks
    And yes i have problem with my computer. Often hardlocks when i'm playing games. Especially BF3. I have tried tweaking with the soundcards etc, no luck. Hope this can tell something.
    It's no problem with heat. Running at maximum 75 celcius.
    I also have the BBC Code 117 all the time when it freezes. I have reinstalled windows TWICE, without luck.
    I have tried several Nvidia drivers incl. beta drivers. No luck. All drivers are up to date.
    When i installed a fresh win7 and installed my drivers from the MSI cd, i noticed that i got this crash. (i tho updated this to new drivers from msi)
    Beskrivning
    Felaktig programsökväg: C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
    Problemsignatur
    Händelsenamn: APPCRASH
    Programnamn: LMS.exe
    Programversion: 7.1.10.1065
    Programtidsstämpel: 4d641645
    Namn på felmodul: StackHash_0a9e
    Modulens version: 0.0.0.0
    Tidsstämpel för felmodul: 00000000
    Undantagskod: c0000005
    Undantagsförskjutning: 74b06c9c
    OS-version: 6.1.7601.2.1.0.768.3
    Språkvariant-ID: 1053
    Ytterligare information 1: 0a9e
    Ytterligare information 2: 0a9e372d3b4ad19135b953a78882e789
    Ytterligare information 3: 0a9e
    Ytterligare information 4: 0a9e372d3b4ad19135b953a78882e789
    Filer som bidrar till att beskriva problemet
    AppCompat.txt
    WERInternalMetadata.xml
    memory.hdmp
    minidump.mdmp
    SFC /SCANNOW Command - System File Checker Attached Files
  10. Posts : 71,959
       #239
    Hello Moojo,
    Looking at your sfcdetails.txt log, there were no issues found with your system files. All is ok with them. :)
    Where you having some sort of issue that you needed help with??
