Page 25 of 99 FirstFirst ... 15232425262735 ... LastLast
  1. Posts : 16
    Windows 7 64 Premium
       #240
    Hmm ok, weird. It said everytime that there were something it couldn't fix.
    Thank you anyway to clear that out.
    Last edited by Brink; 20 Dec 2011 at 12:00. Reason: moved off topic content to it's current thread
  2. Posts : 72,050
       #241
    Moojo,
    Strange, could you post a screenshot of the CMD prompt showing what it says to see what it may be?
  3. Posts : 136
    [Genuine Custom DOS 5.0] & [Genuine Custom Windows 7 Home Premium 64Bit SP1]
       #242
  4. Posts : 72,050
       #243
    Hello iTRiP,
    In that case, you might give OPTION ONE in the tutorial a try instead to run a sfc /scannow in a command prompt at boot.
  5. Posts : 136
       #244
  6. Posts : 72,050
       #245
    You're most welcome. :)
  7. Posts : 136
       #246
  8. Posts : 72,050
       #247
    iTRiP,
    I would recommend to go ahead and create a new thread for this right click issue in the General Discussion forum area to see if we may be able to help with it there since this is going off topic of this tutorial. :)
  9. Posts : 136
       #248
  10. Posts : 72,050
       #249
    No problem mate. I hope that it will be sorted soon for you. :)
