Page 26 of 99 FirstFirst ... 16242526272836 ... LastLast
  1. Posts : 9
    windows 7
       #250
    Hi I googled on how to fix my computer, because of svchost.exe. I came across on this forum. This helped me fixed my computer but I got a little program after finish scaning using the sfc /scannnow. It say some files are corrupted and I looked at the cbs log I dont know how to find out which files is corrupted. Any help?
  2. Posts : 72,050
       #251
    Hello Richard, and welcome to Seven Forums.
    You could use OPTION THREE in the tutoral to create a sfcdetails.txt file to help you know what files the SFC scan was unable to repair. If you like you could also upload a copy of your sfcdetails.txt file here, and I'll be happy to take a look at it. :)
  3. Posts : 9
    windows 7
       #252
    I tried method 3. my command promp say c:\user\xxx. and not c:\window.
  4. Posts : 72,050
       #253
    That means that you didn't open a elevated command prompt (Right click -> Run as administrator) at step 1. :)
    (click here)
    Elevated Command Prompt
  5. Posts : 9
    windows 7
       #254
    Did I do anything wrong? it say it cant open
    sorry took me sometime jus realize I dont have paint no more.
  6. Posts : 72,050
       #255
    Are you logged in an administrator account, and did you open a elevated command prompt like in step 2 and 3 of the tutorial below?
  7. Posts : 9
    windows 7
       #256
    I think I did. I posted a pic above ur post.
  8. Posts : 72,050
       #257
    The elevated command prompt is suppose to open to C:\Windows\System32 instead of C:\Users. Could you give a step by step of what and how you are opening the elevated command prompt to see what may be wrong? I'm suspecting that it may the issue in the yellow tip box at the top of the tutorial.
    In the mean time, try going directly to the C:\Windows\System32\cmd.exe file in Windows Explorer, right click on it, and click on Run as administrator to open the elevated command prompt instead.
  9. Posts : 9
    windows 7
       #258
    just used your way going to the c:windows files and finally i got into c:windows\system32. but when I copy the ting to open the log it still give me cant open. heres a picture to show you.
  10. Posts : 72,050
       #259
    Hmm, ok. See if using the exact command below for your specific user account RICHARD MA name may work for you instead.
    findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"C:\Users\RICHARD MA\Desktop\sfcdetails.txt"
