Page 29 of 99 FirstFirst ... 19272829303139 ... LastLast
  1. Posts : 3
    Windows 7 x64
       #280
    Hi Brink:
    I have been on all sorts of forums trying to find an answer. I have tried to do the scannow, but it says there is a system repair running. It will re-boot but then go right back to that page. Can't extract files from the original Windows disk, since I can't access anything but the system repair - I am on another computer now. No safe mode, nothing! At wit's end!
  2. Posts : 353
    Windows 7 Ultimate
       #281
    I'm trying to open the CBS log that was created and it keeps telling me 'Access Denied' but the file is 16.2mb so it obviously has something inside it.
  3. Posts : 72,046
       #282
    Carol A said:
    Hi Brink:
    Hello Carol, and welcome to Seven Forums.
    You might see if you may be able to run a sfc /scannow command in a command prompt at boot.
    SFC /SCANNOW : Run in Command Prompt at Boot
  4. Posts : 72,046
       #283
    Hello James,
    You should be able to use OPTION THREE in this tutorial to create a sfcdetail.txt file that will only have the SFC scan results for this. :)
  5. Posts : 353
    Windows 7 Ultimate
       #284
    Brink said:
    Hello James,
    Thanks, I really need to start reading the whole thread before replying
  6. Posts : 72,046
       #285
    LOL
  7. Posts : 353
    Windows 7 Ultimate
       #286
    Brink said:
    LOL
    It 'repaired' explorer.exe when the only thing it actually did was remove my custom start button
  8. Posts : 72,046
       #287
    That would be correct. A sfc /scannow command will attempt to repair and replace corrupted or modified system files with a clean default one.
  9. Posts : 353
    Windows 7 Ultimate
       #288
    There wasn't anything else corrupted as i've just done a clean install of Windows 7 :)
    Edit: 150 posts!
  10. Posts : 72,046
       #289
    ...but it was "modified" (custom start button), thus repaired by restoring the file to default.
