Page 30 of 99 FirstFirst ... 20282930313240 ... LastLast
  1. Posts : 353
    Windows 7 Ultimate
       #290
    Brink said:
    ...but it was "modified" (custom start button), thus repaired by restoring the file to default.
    So sfc just replaces any corrupt (or modified) files? Nice
  2. Posts : 3
    Windows 7 x64
       #291
    Didn't work - went right back to startup repair...
    And thanks for the welcome! Forgot my manners :)
  3. Posts : 72,116
       #292
    Carol,
    Go ahead and run startup repair, up to 3 times if needed, to see if it will start into Windows afterwards. If not, then see if the tutorial may be able to help. :)
  4. Posts : 3
    Windows 7 x64
       #293
    Thanks for your help, but that didn't work either. Doing a re-install now
    Glad I backed up!
  5. Posts : 72,116
       #294
    You're welcome Carol. I hope it goes smoothly for you.
  6. Posts : 3
    Home Premium 32 bit
       #295
    New to this forum and obviously here as I have snags. Running windows 7 home premium or should I say trying to! Both Windows explorer and Internet explorer move at a snails pace most of the time showing (not responding) the displayed page turns white when not responding as does the task bar following start up. Have tried sfc /scannow as described above but it only completes 2% and then states it cannot complete the task, tried this operation about 12 times but no luck. Any advice please.
  7. Posts : 21,004
       #296
    Hiyya Garry welcome to SF and I have to say I am no great expert mate but it would be helpful to have a few system specs posted.
    Try the tutorials and type in "how to run scannow" in the search bar when it comes up - tuts are real helpful as I found them when I first joined - good luck!
    Ooops just seen I am on the end of it
  8. Posts : 72,116
       #297
    Hello Garry, and welcome to Seven Forums.
    If you have not already, you might see if you may be able to do OPTION ONE in the tutorial to run SFC at boot.
  9. Posts : 3
    Home Premium 32 bit
       #298
    Hi Brink,
    THANKS TRIED OPTION AND RAN SFC AT BOOT BUT NOT CHANGE TO MY PRESENT ISSUES.
  10. Posts : 72,116
       #299
    Garry,
    Just to be safe, do a full scan of your system with Malwarebytes free to help make sure that your system is clean.
