#310
what else is??
I've replaced my login screen and SFC /verifyonly reflects that as a corrupt file. This is ok because I know why it finds it corrupt. None of my other files show to be bad.
However, I have some concern that, if some of the inconsequential source files are corrupt for an unknown reason, others may be corrupt also. In that case, as long as your operating files are OK, SFC will find no issues, even if the other OS source files are corrupt. That means you may not know that you don't have a working source file until you need it.
Or do I understand the operation of SFC incorrectly?
