Page 33 of 99 FirstFirst ... 23313233343543 ... LastLast
  1. Posts : 225
    Brink said:
    Hello sle3pingz,
    That would mean that the SFC scan did not find any issues (corrupted or modified) with only your Windows system files. :)
    is that mean nothing corrupted or wrong with my windows system files right?
  2. Posts : 72,051
       #321
    Correct. :)
  3. Posts : 225
    Brink said:
    Correct. :)
    ok , Thanks for you fast respond again Brink ~
  4. Posts : 72,051
       #323
    You're most welcome. :)
  5. Posts : 54
       #324
    System File checker results
    Brink,
    This is wonderful that you have given so time and knowhow for us all. I will to send in the sickest report.
    Best, Avie
    SFC /SCANNOW Command - System File Checker Attached Files
  6. Posts : 72,051
       #325
    Hello Avie,
    From your log, you have to many to list here, and to try and fix manually. They are just about all corrupted file for Windows Defender and Windows Mail.
    I would recommend to do a full scan of your system with Malwarebytes free to help make sure that your system is clean. Afterwards, install and use Microsoft Security Essentials (MSE) that will replace Windows Defender.
  7. Posts : 54
       #326
    File Checker errors
    Hey thank you. I ahve done what you suggested and nothing is showing. I had to reinstall WSE this am because I could not find it under programs or control panel
    I did find a error to turn on WSE and it will not respond. It is turned off and stays that way. ugh?
  8. Posts : 72,051
       #327
    Do you mean MSE or Windows Defender?
    MSE disables Windows Defender since MSE is used instead.
  9. Posts : 54
       #328
    Scannow-WSE
    I had to reinstall M Sec Essen. It will not turn on in Action Center. Defender is long gone when I removed the service line.
  10. Posts : 72,051
       #329
    What is the "service line" that you removed?
    Do you mean that you deleted the "Windows Defender Service"?
