Page 37 of 99 FirstFirst ... 27353637383947 ... LastLast
  1. Posts : 1
    Windows 7 Home
       #360
    After SFC scan "Windows Resource Protection found corrupt files" error
    Thanks for the brilliant posts!!
    Tried to install a transformation pack but meanwhile got an error "BOOTMGR corrupt, unable to boot"...later googled & followed your posts & tried the steps as mentioned in ur posts. But now after the sfc scan it shows an error as "Windows Resource Protection found corrupt files but was unable to fix some of them. details are included in CBS.log. windir\logs\CBS\CBS.log For example C:\Windows\logs\CBS\CBS.log".
    kindly suggest how to proceed & recover the OS...!!
  2. Posts : 72,078
       #361
    Hell Techneis, and welcome to Seven Forums. :)
    If you like, go ahead and do OPTION THREE to post back with your uploaded sfcdetails.txt file. I'll be happy to take a look at it. :)
  3. sei
    Windows 7 Home premium 64bit
       #362
    Sorry to disturb you, but after running a sfc /scannow command, I have some dammages files which are the msi.dll (I put my report in joined files)
    I read all the topics and the tutorials and know what to do now thanks to you.
    But when I bought my pc, I didn't have the Windows 7 home premium installation cd because it's a Sony Vaio (and they don't give the OS intallation cd anymore but make you to burn a reinstallation cd...) and I don't want to reinstall the whole thing. I just need a clean msi.dll, Can someone upload it for me please ?
    Thank you in advance.
    SFC /SCANNOW Command - System File Checker Attached Files
  4. Posts : 6,458
       #363
    sei: This should help you get your system files back in order. It's a large download and runs for quite a while.
  5. sei
       #364
    Slartybat : Thank you sooooooo much ! It's working I can install new programs again ! You were so fast ! Thank you again !
  6. Posts : 6,458
       #365
    sei: glad to be of assitance. I onced worked at SEI (Valley Forge, PA)
  7. Posts : 19
    window 7 ultimate 32bit
       #366
    Hello,i have one problem,,why after 12 percent scan its show warning its says 'windows resources protection could not perform the rrquest operation.
  8. Posts : 51
    Does the corrupted files affects system performance? What is the benefit of repairing system files? Thank you for this very informative tutorial!!
  9. Posts : 72,078
       #368
    Hello Jan,
    It really depends on what system files have been modified, corrupted, or missing. Some could affect system performance, while others may only affect you being able to do something. If the file had been modified by you, then it will be considered to be corrupted since it's not default.
    The main benefit of running a "sfc /scannow" command is to restore any modified, corrupted, or missing system files back to their default state. :)
  10. Posts : 47
    Windows 7 Ultimate 64-bit
       #369
    sfc /scannow
    Ran the scan, but when I went to C:WINDOWS\logs\cbs, I couldn't open the CBS text file. I got a message "Access Denied". Say what?
