Page 40 of 99 FirstFirst ... 30383940414250 ... LastLast
  1. Posts : 72,037
       #390
    No worries. It's not going to damage your system. The SFC scan is designed to try and repair any corrupted or modified system files it finds back to a default state.
    System files are not settings, so unless you used a program like Resource Hacker to modify a system file, then you have nothing to worry about.
    If you like, you could create a restore point before running the SFC scan. This way if it undoes anything you don't want undone, you could do a system restore using the restore point to undo what the SFC scan did.
  2. Posts : 32
    Win 7 32
       #391
    thanks SO MUCH just the info I needed. In much appreciation and Merry Christmas or Happy Hanukah! Debra1533
  3. Posts : 32
    Win 7 32
       #392
    My SFC scan came out clean. Since this was done as a result of recent crashes; I was a bit worried about logging out then in to create this same scan to the boot bios. Is this recommended for someone who's having crashes? If you read earlier there's no problems from CCleaner, Malwarebites and Vipre. Thanks Debra1533
  4. Posts : 72,037
       #393
    You're welcome Debra.
    I hope you have a Happy Holidays as well. Thank you. :)
    Since this is involving your computer crashing, you should see the link below, then post the needed information in the Crashes and Debugging forum area. We'll be happy to see what we can do to help.
    https://www.sevenforums.com/crashes-d...tructions.html
  5. Posts : 47
    Windows 7 Ultimate 64-bit
       #394
    What when you get the reply "Windows Resource Protection could not start the repair service"?
  6. Posts : 72,037
       #395
    Hello Billy,
    Check to see if using the yellow TIP box at the top of the tutorial may be able to help with this error. :)
  7. Posts : 47
       #396
    It was useless for this. After I ran the scan, and got that message, I also did a "FixNCR" on it and it just cleaned up it's act. I hate it when it does that! Now, I'll just sit around looking and waiting for it to do something again! Sux...
  8. Posts : 72,037
       #397
    Hopefully it won't get another error again. :)
  9. Posts : 47
       #398
    Hopefully...
    Thanks for your help. I get a lot of experience in a lot of other areas.
  10. Posts : 47
       #399
    I think it probably will. I am one who expect quirps. I just hope I can learn to resolve the problems. That's what makes it fun for me!
