Page 41 of 99 FirstFirst ... 31394041424351 ... LastLast
  1. Posts : 47
    Windows 7 Ultimate 64-bit
       #400
    Or, should that be "quirks"? Who knows? Better yet, who cares?!
  2. Posts : 17
    windows 7 home premium x64
       #401
    Anyone care to check this sfc output?
    Excellent thread and I have been using sfc for quite some time now. All along, the output file on this one machine (gaming and home/office box) has been reporting an issue with one of the market theme packs (for which there is another on-line solution to delete entire themes). Should i be worried about this AU market theme pack problem... see attached text.
    I know this is an old thread... but it's durability is a sign of value!! Thanks Brink.
    SFC /SCANNOW Command - System File Checker Attached Files
  3. Posts : 72,043
       #402
    Hello jmallamo, and welcome to Seven Forums.
    It says that you have a desktop.ini file that cannot be repaired for "Microsoft-Windows-LocalPack-AU-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.LocalPack-AU". This is a language pack.
    It's nothing to worry about though. :)
  4. Posts : 17
       #403
    Thank you Brink. And for the link to the language pack thread, unfortunately I have W7 HPx64. Anyway, it's not an issue as you say.
    j
  5. Posts : 72,043
       #404
    You're welcome. :)
  6. Posts : 9
    Hi there everyone. New here but i see that you actually get some pro help here. :) So i hope someone would please help me look at this log from a sfc /scannow. In advance thanks a mill. Greetings from Norway :)
  7. Posts : 72,043
       #406
    Hello Bernt, and welcome Seven Forums.
    It looks like you have a few corrupted files for Microsoft Multiplayer Inbox Games - Spade. Reinstalling it may fix them if you are having any issues with the game.
    Hope this helps, :)
  8. Posts : 9
    Thank you so much for helping. Ill try and fix this, if not ill be back. :)
  9. Posts : 9
    Ok, i removed that Spade-restarted and added it again-restarted and run sfc /scannow. Still some issue, but the log file look different now. Added the new log.
  10. Posts : 72,043
       #409
    It's for the same files. If you are not having any issues with the game, then I wouldn't worry about it.
    Personally, I would leave the game uninstalled if installed with corrupted files though.
