Page 43 of 99 FirstFirst ... 33414243444553 ... LastLast
  1. Posts : 4,049
       #420
    Preferred Option
    I'm going to recommend a clean reinstall (as my preferred option).
    He has a lot of random stuff on his laptop.
    I'd be surprised if he still uses all of it (he tends to install programs and then only use them once or twice).
    It doesn't take that long to reinstall Windows and programs (and he has an SSD).
    He just started 2 months Long Service Leave (that should be ample time).
    If he doesn't want to do that, then I'll follow the "view the CBS log and replace the corrupt files" option. :)
  2. Posts : 72,051
       #421
    Agreed. Clean installs always (well usually) give good results.
  3. Posts : 6
    Windows 7 home basic 32bit
       #422
    Can somebody please help me. I tried sfc/SCANNOW and a massage saying 'you have to be an administrator running a console session in order to use the sfc utility'. I hve only one user account in this laptop and it is an administrator account. Please help me with this problem
  4. Posts : 19,383
       #423
    You need to do this:
    Elevated Command Prompt
    1. Click Start
    2. In the search box, type cmd
    3. In the list that appears, right-click on cmd.exe and choose Run as administrator
    4. In the command window that opens, type sfc /scannow and hit enter.
    Regards,
    Golden
    Last edited by Brink; 03 Feb 2013 at 01:36. Reason: added tutorial link for more info
  5. Posts : 47
    Windows 7 Ultimate 64-bit
       #424
    sfc/scannow
    Brink, when I first posted on this thread, it was because ny "Windows Explorer" was running too slow to be bearable. I assumed that through all of the comments and tests and scans, that I would be working OK. Well, PHOOEY to that! Is there anything we may have missed trying to find a solution to this problem? It stopped for a long time, but started again last night. This is the system that I do EVERYTHING on, so you can imagine how frustrating it is to have the primary system tool screw up like that.
    Any new suggestions as to why Explorer even does that?
  6. Posts : 72,051
       #425
    Hello Billy,
    Sorry to hear that it's acting up on you again.
    You might see if doing a system restore using a restore point dated before this started again may be able to undo what caused it and fix it.
  7. Posts : 47
       #426
    sfc/scannow
    Yeah, I did a "Startup Repair", which said it couldn't fix the problem, and sent a report, and it has worked since. I don't know what this is...
  8. Posts : 72,051
       #427
    Glad to hear it has worked since.
  9. Posts : 60
    Win7 Professional x64
       #428
    Quick question about SFC.. How do I read the logs?
    is a
      0000032f [SR] Beginning Verify and Repair transaction
     Repair results created:
    an indication that something has been fixed or is that general output? after that snippet, there was some "move file" commands taking place..
  10. Posts : 72,051
       #429
    Hello catch22,
    If you like, use OPTION THREE to create a sfcdetails.txt file, and upload it. I'll be happy to take a look at it, and post with some explanations to help read it. :)
