Page 44 of 99 FirstFirst ... 34424344454654 ... LastLast
  1. Posts : 60
    Win7 Professional x64
       #430
    well, I just ran it again, it said Windows Resource Protection didn't find any integrity violations. Is it still plausible to run it to detect errors?
  2. Posts : 72,051
       #431
    That message means that it didn't find anything wrong with your system files.
  3. Posts : 141
    Windows 7 Home Premium x64, *W7 Prem. x64
       #432
    ...Hello friends....
    ...Can someone help me to understand..., when I "run" sfc /scannow, in cbs.log, I found "thousand" of:
    -Move File: Source = [....] "\SystemRoot\WinSxS\Temp\PendingRenames\...........cdf-ms", Destination = ......-
    ..what it means (about..), after the procedure (scannow), everything will be o.k.? is it a critical problem?
    ....Thanks for informations ..(if any or not..)
  4. Posts : 72,051
       #433
    Hello Notis,
    Please go ahead and post back with your uploaded sfcdetails.txt file from OPTION THREE, and we'll take a look at them to see what all it did. :)
  5. Posts : 141
       #434
    Hello Brink and thank you..
    I didn't want to "bother" you, for a deep analyse...because soon (hoping..), I'll clean install...
    But, very often (maybe always!) I see in cbs.log this "event" of -Move file....Destination...
    ...and I wanted to learn "at least"..what is about...Also I am sure other people have the same question...
    ...So I post the cbs.log where I see this procedure...and I attach also the sfcdetail.txt you asked, where..(surprise!)
    ...is just ONE!..only repair....I'm very interested to get any information...about..
    Thanks again...
    Attachment 258089 sfcdetails.txt
  6. Posts : 72,051
       #435
    notis,
    The SFC log shows that it found the file below corrupted. It was able to repair it, so you're all good. :)
    C:\Windows\System32\lpremove.exe
    That file is for MUI Language pack cleanup.
  7. Posts : 141
       #436
    Thank you Brink.
    ....thanks for your patience too...
  8. Posts : 72,051
       #437
    You're most welcome notis. :)
  9. Posts : 66
    Microsoft Windows 7 Home Premium 64-bit SP1
       #438
    2. In the elevated command prompt, copy and paste the command below, and press Enter. (See screenshot below)
    NOTE: This will place a sfcdetails.txt file on your desktop with only the SFC scan result details from the CBS.LOG in it.
    when I opened the file sfcdetails.txt in notepad it was empty, is that right?
  10. Posts : 72,051
       #439
    Hello Julie,
    Only if you didn't run SFC first.
    Hope this helps for now, :)
