Page 47 of 99 FirstFirst ... 37454647484957 ... LastLast
  1. Posts : 71,977
       #460
    stasioau said:
    Hi Brink,
    Try to use: “SFC /SCANNOW Command - System File Checker”
    Some time ago I do not have good experience using this method, special with: Aero, Window Color, Sounds.
    With sounds you help me in “How to Change the Windows 7 Start up Sound”
    Before I start my work I was looking for your:
    "Warning
    Be aware that if you have modified your system files as in theming explorer/system files, running sfc /scannow will revert the system files such as explorer.exe back to it's default state. Make the appropriate backups of your system files that you have modified for theming if you wish to save them before running sfc /scannow".
    How to make backup on my system, to be sure that “Aero” and “Window Color” come back after sfc /scannow ? Can I use “Restore Point”, or “System Restore”? Or make backup “C:” in additional hard disk?
    When I finish my sfc /snannow work, how I can back to my modification before work?
    Wish you all the best. With my best regards
    stasioau
    Hello Stasioau,
    You could use step 3 in OPTION TWO to only verify if there are any corrupted or modified system files instead. This way your modified system files will not be changed. :)
  2. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #461
    Stasioau
    You could find the theme you were using in this location
    C:\Windows\Resources\Themes
    [note] You will have to patch the 3 .DLL Files using the Universal Theme Patcher
    3 DLLs files
    themeservice.dll
    themeui.dll
    uxtheme.dll
  3. Posts : 103
    Brink and VistaKing,
    Thanks so much. All my questions been explained.
    Wish you all the best,
    stasioau
  4. Posts : 71,977
       #463
    Glad we could help Stasioau. :)
  5. Posts : 1
    Punjab
       #464
    Thanks alot
  6. Posts : 71,977
       #465
    Welcome to Seven Forums Saadq. :)
  7. Posts : 5
    unable to repair after power outage
    Good Afternoon,
    win 7 x64 Ultimate
    Ran sfc after power outage.
    System seems to be working fine but i ran sfc /scannow anyway several times and still getting errors.
    If possible, can you review the log file and let me know if I should go to any length to repair...
  8. Posts : 71,977
       #467
    Hello Marc, and welcome to Seven Forums.
    Sure thing. You could use OPTION THREE to upload your sfcdetails.txt file with the details. :)
  9. Posts : 5
    Thank you, trying again to upload log.
    looks like I might have problems.
    monitor sleeps after 5 minutes and wont come back.
    changed power settings to never for everything
    SFC /SCANNOW Command - System File Checker Attached Files
  10. Posts : 71,977
       #469
    Marc,
    If you are not having any issues, then I wouldn't worry about it for now. If you are, then you may need to do a repair install to fix these unrepairable system files.
