Page 56 of 99 FirstFirst ... 46545556575866 ... LastLast
  1. Posts : 72,191
       #550
    Azri Bovier said:
    There was an error on event log..said kernel power error..and when ever I try to chkdisk at the startup it crashes
    Edit: sorry if this is unrelated to the thread discussion
    Since this is a "kernal power error" issue, please go ahead and follow the instructions at the link below, and create a new thread in the BSOD Help and Support forum area with the needed details and information.
    Blue Screen of Death (BSOD) Posting Instructions
  2. Posts : 3
    Windows 7 Pro x64
       #551
    Hi everyone.
    Can someone help with the SFC error i am getting.
    I have run it three times, i have even tried repairing from windows 7 disk with no luck.
    it get stuck at 59% everytime
    SFC /SCANNOW Command - System File Checker Attached Files
  3. Posts : 72,191
       #552
    Hello Malanh, and welcome to Seven Forums.
    So far in your log, SFC hasn't found any corrupted files.
    You might run chkdsk on your C: (Windows) drive to see if that may allow SFC to finish afterwards.
    If not, the you could give running the System Update Readiness Tool listed in the blue Note box under step 4 in Option Two.
    Hope this helps for now, :)
  4. Posts : 3
    Windows 7 Pro x64
       #553
    Hi Shawn,
    Thanks for replying.
    I ran chkdsk and it completed with no errors.
    attached is a copy of a complete cbs.log
    I think it may be something to do with zeroaccess.
    scans don't find anything wrong, SFC seems to be the only indication something is wrong
    This all started when i was trying to update antivirus, initially windows firewall and the base filtering engine wasn't running. now im stuck on the security center service not being in the services list.
    Mathew
  5. Posts : 72,191
       #554
    Mathew,
    Sometimes SFC may take a bit to finish.
    Are you or were you infected with zeroaccess? It sounds like you are. I would recommend to do a full scan of your system to help make sure that your system is clean. Personally, when it comes to viruses and trojans, I prefer doing a clean install.
  6. Posts : 3
    Windows 7 Pro x64
       #555
    I ended up running through this process
    How to remove Sirefef Trojan (Removal Guide)
    the sfc scan now completes succesfully, and all seems well.
  7. Posts : 72,191
       #556
    Great news Mathew. Thank you for posting back. :)
  8. Posts : 5
    hello folks sorry its been awhile since I posted. I've been really busy and haven't had time to work on this. I've tried all those options and none of them worked, however I did find a a different tool here .NET Framework Setup Verification Tool User's Guide - Aaron Stebner's WebLog - Site Home - MSDN Blogs and made me remember I had patched my themes .dll files for new visual styles and I'm thinking that has something to do with my problems. I attached the log file after it failed trying to verify the .NET framework 2.0 SP2 install.
  9. Posts : 72,191
       #558
    Hello metalcut,
    At this point, you might consider reinstalling Windows.
  10. Posts : 103
    Hi, I am sorry of my primitive question.
    After run "sfc /scannow" have problem with my "Window Colorization". Does not work what kind of Aero Themes I can choose. Always I get typical Window Color and Appearance not list of colors.
    Will appreciate help.
