Page 62 of 99 FirstFirst ... 52606162636472 ... LastLast
  1. Posts : 7
    Windows 7 pro 64 bit
       #610
    Okay, ran the program, rebooted, ran SFC \scannow 4 times then reviewed report. All the same errors are there with the addition of 3 new ones...
    Cannot verify component files for Microsoft-Windows-DirectWrite.Resources, Version = 7.1.7601.16492, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"cs-CZ", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, manifest is damaged (TRUE)
    Cannot verify component files for Win7-Microsoft-Windows-DownlevelApisets-Base-WinIP-Deployment-LanguagePack, Version = 7.1.7601.16492, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"es-ES", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, manifest is damaged (TRUE)
    Cannot verify component files for Win7-Microsoft-Windows-DownlevelApisets-Windows-WinIP-Deployment-LanguagePack, Version = 7.1.7601.16492, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"et-EE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, manifest is damaged (TRUE)
    Any guidance on what next?
    Thank again
  2. Posts : 72,049
       #611
    If you're not having any issues, then I would worry about it. Otherwise, you may need to do a repair install or clean install.
  3. Posts : 7
       #612
    Thanks Brink. The only issue I have remaining is an occasional freeze, which requires I do a hard restart. I might just have to do the repair install, although it seems with my luck I would be just opening a whole new can of worms...LOL
    We'll see how much the freezing annoys me and go from there. Thanks again.
  4. Posts : 72,049
       #613
    Hopefully you won't need to.
  5. Posts : 64
    Windows 7 Home Premium 32-bit
       #614
    Good afternoon Brink. I tried to sfc /scannow my pc. And the result is on the .zip file attached. Please help me what to do, I do not know how. Thank you.
  6. Posts : 72,049
       #615
    Hello Ryan,
    If you have not already, see if the items listed in the blue note box under step 4 in OPTION TWO may be able to help. :)
  7. Posts : 64
       #616
    Brink said:
    Hello Ryan,
    I try tonight, and will post the result. Thank you Brink. :)
  8. Posts : 64
       #617
    Still having the same result: "Windows Resource Protection found corrupt files but was unable to fix some of them." I tried options 1 and 2 in number 4 notes. In addition, I cannot perform the other options because I do not have the installation cd of this unit. The result is attached herewith in a .zip file.
  9. Posts : 72,049
       #618
    It looks like you tried to add Group Policy to your Home Premium edition which is not supported. That's why these files are found to be corrupted, and cannot be repaired.
  10. Posts : 64
       #619
    You're right, I installed gpedit.msc in my unit. But I uninstalled it last year. Does it leave any traces? Last night, when doing something, I tried to run gpedit.msc, and alas! It is still there though I uninstalled it.
    What should I do?
