Page 64 of 99 FirstFirst ... 54626364656674 ... LastLast
  1. Posts : 1
    Windows 7 Ultimate x86
       #630
    please help me,, my seven is always getting error 0xc000007b when i want run some app.
    i do a sfc /scannow and this is the message
    Microsoft Windows [Version 6.1.7600]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Windows\system32>sfc /scannow
    Beginning system scan. This process will take some time.
    Beginning verification phase of system scan.
    Verification 100% complete.
    Windows Resource Protection found corrupt files but was unable to fix some of th
    em.
    Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example
    C:\Windows\Logs\CBS\CBS.log
    The system file repair changes will take effect after the next reboot.
    and the CBS.log file already i switched to sfcdetails.txt
    help me, thanks before
    SFC /SCANNOW Command - System File Checker Attached Files
  2. Posts : 72,061
       #631
    Hello dodoupload, and welcome to Seven Forums. :)
    Wow, you have a lot of corrupted or modified system files there. For now, see if doing what's listed in the blue note box under step 4 in Option Two may help.
  3. Posts : 5
    7 64bit ultimate
       #632
    Hi Brink,
    Is it possible to have a look at my file? Was trying to installed .net framework 3.5 on a Win7 64bit Ultimate, i end up in this forum from my research and after spending many hours trying to figure out why a software that i have on my pc keep's crushing on me!, and then , the software creator said that i need .net 3.5 , now i can't install this !
    So if you can can you take a look? is all the CBS file as for some reason my pc has c:\user... not c:\windows...
    Thank you,
    Regards.
  4. Posts : 72,061
       #633
    Hello Jack, and welcome to Seven Forums.
    Your SFC details do not show it found any corrupted system files.
    I would recommend to create a new thread in the Software forum area for this issue to see what we can do to help. :)
  5. Posts : 5
    7 64bit ultimate
       #634
    @Brink, Thank you for replying!
    I did open a new tread here:
    https://www.sevenforums.com/software/...ml#post2778478
    Thank you!.
  6. Posts : 72,061
       #635
    You're welcome. I hope you will get a solution soon. :)
  7. Posts : 1
    Windows 7 Ultimate 32 Bit
       #636
    need help deciphering this
    here's the results of my SFC scan could yo uhelp me figure it out? thanks a lot
  8. Posts : 72,061
       #637
    Hello Clifford, and welcome to Seven Forums.
    You SFC details show that the mf.dll (Media Foundation DLL) system file cannot be repaired.
    You could see if doing what's in the blue note box under step 4 in Option Two may help. :)
  9. Posts : 15
    Windows 8.1 (64 bit)
       #638
    Hello guys! Jimmy here.
    A week ago I tried to run sfc /scannow but since then it has shown me that it was unable to fix some corrupted and still is unable to do so, I uploaded the sfcdetails from desktop. I gave up trying to download all required updates from Microsoft as it still showed me the message. Btw I use Windows 7 Ultimate x64 with the latest updates installed.
    Thanks a lot, in advance!!!
    sfcdetails.txt
  10. Posts : 72,061
       #639
    Hello Chris, and welcome to Seven Forums.
    For now, you might see if doing the items listed in the blue note box under step 4 in Option Two may be able to allow SFC to repair the file afterwards. :)
