Page 71 of 99 FirstFirst ... 61697071727381 ... LastLast
  1. Posts : 72,052
       #700
    Yeah, it'll recreate it.
  2. Posts : 8
    windows 7 home premium 64bit
       #701
    already done that but the new ones just the same. All this is to find out how to cure a propsys.dll error, not sure if thats affecting this as well ..
  3. Posts : 72,052
       #702
    In that case, you might see if doing a system restore using a restore point dated before this happened may be able to undo and fix this error.
  4. Posts : 8
       #703
    all, sorted now and thanks for the help.
  5. Posts : 72,052
       #704
    Great news. You're most welcome. :)
  6. Posts : 21
    Windows 7 Ultimate X64
       #705
    What is wrong here? (after cloning from a dying OCZ Vector - which come up as fine - to a Samsung 850 PRO)
    SFC /SCANNOW Command - System File Checker Attached Files
  7. Posts : 72,052
       #706
    Hello Ganon,
    Your sfcdetails.txt log doesn't show any corrupted files found. :)
  8. Posts : 21
       #707
    Brink said:
    Hello Ganon,
    I thought that ... But sfc says corrupted files found? (Is it just a strange anomaly?)
  9. Posts : 72,052
       #708
    Did you run SFC from within Windows when it said that? It doesn't log if you ran SFC at boot.
    If you like, try again, then create a new sfcdetails.txt file to post to see if it may show anything.
  10. Posts : 21
       #709
    Just ran it again. Here are the results:
    Attached Thumbnails Attached Thumbnails SFC /SCANNOW Command - System File Checker-sfc.png
