Page 73 of 99 FirstFirst ... 63717273747583 ... LastLast
  1. Posts : 72,059
       #720
    Hello Haramo,
    Your SFC details show that it was unable to repair the settings.ini file for Microsoft-Windows-Sidebar. If you manually added "Windows Sidebar" back to Windows 7, then that would be why it can't repair the file since it's not included in Windows 7 by default.
    If you are not having any issues with it, then there's nothing to worry about. :)
  2. Posts : 18
    windows 7 home premium SP1 64bits
       #721
    Hmmm, it comes to me that maybe im in the wrong forum, i think it's windows vista on the system. Chdsk is now buzzy.
  3. Posts : 72,059
       #722
    You can use the same method below, but look at the top in "System" to see if it's Vista or Windows 7 installed. :)
    System Type - 32-bit (x86) or 64-bit (x64)
  4. Posts : 18
       #723
    Chkdsk has finished.
    W
    indows vista home basic, Service Pack 2, 32 bit.
    I'm sorry This laptop is from my neighbour. Not mine. as my info on this forum is from my laptop.
  5. Posts : 72,059
       #724
    Is your neighbor's computer having any issues with Windows Sidebar?
    If not, then there's nothing to worry about trying to repair.
  6. Posts : 18
       #725
    No, no problems, it works, but the booting time is very slow. After the laptop is cleaned, it still need a lot of time to boot, load everything. I'm trying to speed up the boot a little bit.
  7. Posts : 72,059
       #726
    In addition, you might see if this below may help some with performance. :)
    Optimize Windows 7
  8. Posts : 18
       #727
    Is there also an optimize for vista?
  9. Posts : 17,322
    Win 10 Pro x64
       #728
    There is this,
    Speed Up the Performance of Vista
    A lot of the same stuff that's in the optimize for Seven.
  10. Posts : 18
       #729
    Ok, thanks a lot
