Page 75 of 99 FirstFirst ... 65737475767785 ... LastLast
  1. Posts : 30
    Windows 7 Home Premium 32bit
       #740
    Thank you for the prompt reply.
    Is it possible to do something with/about these files, so that when I run sfc /scannow command i'll know that everything is right. And yes, I do not use or need those sample music and photo. Is it possible to simply delete (or repair) them?
  2. Posts : 72,058
       #741
    You could try what's in the blue note box to see if SFC may be able to repair them afterwards. Otherwise, it's safe to ignore this.
  3. Posts : 30
       #742
    Sorry, I am not clear, what is that blue note box? Where is it?
  4. Posts : 72,058
       #743
    The blue note box at the bottom of OPTION TWO in the tutorial. :)
  5. Posts : 30
       #744
    Oh, I see, thank you.
  6. Posts : 103
    sfc /scannow
    Sorry, I do not have CBS.log. In Windows, logs, CBS, I do have CBS only. Can not open it "Access is denied". Will appreciate your comments please.
    Best regards,
    stasioau
  7. Posts : 72,058
       #746
    Hello Stasioau,
    That should be it. Please see if you can do OPTION THREE in the tutorial to create a sfcdetails.txt file to upload here. :)
  8. Posts : 103
    Thanks Brink.
    Used Option Three and copy line to CMD. Get "sfcdetails" on desk. Empty. Go again to work with "sfc" nothing change again.
    Something doing wrong.
    Best regards
    stasioau
  9. Posts : 72,058
       #748
    Stasioau,
    If you're running SFC in safe mode, you wouldn't have it reported in the CBS file. Are you running SFC from within Windows?
  10. Posts : 103
    Hi Brink,
    Repeat Option Three, get "sfcdetails" on desktop with all information.
    Have number of corrupted files. Attach short list.
    Any your comments will appreciate.
    Cannot repair member file [l:20{10}]"locdrv.cab" of Microsoft-Windows-LocalizedDrivers, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9)
    Cannot repair member file [l:20{10}]"locdrv.cab" of Microsoft-Windows-LocalizedDrivers, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
    Cannot repair member file [l:24{12}]"spwizimg.dll" of Microsoft-Windows-Setup-Navigation-Wizard-Framework, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
    Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:24{12}]"spwizimg.dll"; source file in store is also corrupted
    Cannot repair member file [l:28{14}]"background.bmp" of Setup-UXWizard-ClientImages, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    Cannot repair member file [l:24{12}]"spwizimg.dll" of Microsoft-Windows-Setup-Navigation-Wizard-Framework, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    Cannot repair member file [l:20{10}]"locdrv.cab" of Microsoft-Windows-LocalizedDrivers,Cannot repair member file [l:24{12}]"spwizimg.dll" of Microsoft-Windows-Setup-Navigation-Wizard-Framework,
