Page 77 of 99 FirstFirst ... 67757677787987 ... LastLast
  1. Posts : 3
    Windows 7 Professional SP1 64b (with virtualization enabled)
       #760
    sfcdetails.txt
    Thanks for the quick response. sfcdetails.txt attached. :)
    Jerry
  2. Posts : 72,049
       #761
    The few files that can't be repaired are related to Microsoft-Windows-Unified-Telemetry-Client from the KB3022345 update.
    You can uninstall the KB3022345 Windows Update. When finished, check for any new updates and install.
    Windows Update - Uninstall an Update
    Are you having any issues from this other than SFC not being able to repair the files?
  3. Posts : 3
       #762
    Mission accomplished
    Thanks, that did the trick.
    Uninstalled the KB3022345 update and reran sfc /scannow. It now runs with no problems found at all.
    I've noticed no other problems, unless the inability to run SURT counts.
    I expect to reinstall the KB3022345 update if update tells me it is still needed and rerun scannow. If the problem repeats I'll get back on this thread.
    FYI some background. I only ran scannow because Kaspersky told me I had acquired some "unprocessed objects - legal software that can be used to hurt your computer" . Elimination required what Kaspersky called "Advanced Disinfection" multiple times. As I emerged from that, there were messages telling me that several .dll files were " not designed to operate with windows or were corrupted". An HP tutorial had told me about scannow as a recovery from corrupted windows files and so I ran it. It must have fixed most of the problems but left those last two that you have helped me with. Thanks again.
    Jerry
  4. Posts : 2
    Windows 7 Home Premium 64-bit
       #763
    Hi guys,
    So I've been experiencing crashes to black or blue screen once or twice a day for the past while. Running a sfc scan 4 or 5 times as you suggest found that there were corrupt files and that not all of them could be repaired. I went through the blue box for option three and tried all the steps (Except the repair install as I do not have a Windows disc and system restore as, for whatever reason, my pc was not making regular restore points as I assumed it would have been). Unfortunately, however, the sfc scan still shows corrupt files and the crashes persist.
    I was wondering, then, if anybody wouldn't mind having a look through my sfcdetails.txt and giving me some tips as to how I might go about replacing the corrupt files manually.
    Thanks a heap
    Tom
    SFC /SCANNOW Command - System File Checker Attached Files
  5. Posts : 13,576
    Did you remove the update Brink listed above ?
    The update causes a false corruption reading in sfc, this has been going on for months.
  6. Posts : 2
       #765
    Yep AddRAM, I noticed those posts just as I posted. Reinstalled the update and just ran an sfc and no more corruption readings. I guess my crashes, then, are unrelated but it's good to have ruled this out.
    Thanks again
    Tom
  7. Posts : 71
    Windows 7 64 bit
       #766
    Hi Guys, ran sfc and some files corrupted. Looked at log but it is double dutch to me. If someone has time to have a look it would be a great help.
    Text file in dropbox https://www.dropbox.com/s/wl01n8hn6iuostg/CBS.log?dl=0
    thanks.
  8. Posts : 72,049
       #767
    Hello Fergiet,
    You're fine. It just a false positive for the KB3068708 update file mismatch issue. No need to do anything. :)
  9. Posts : 71
    Windows 7 64 bit
       #768
    Thanks for the help. The log files were no help to me.
  10. Posts : 3
    KY, Windows 7 Home Premium, 64 Bit
       #769
    How do you know which update is causing corruption?
    Brink, Thanks for being such a great and understandable resource. I have run sfc and gotten the attached .txt file. How can you tell which update is causing a corruption or false reading? Do I need to take action on the corruptions sfc has detected. My Windows 7 OS seems to be doing its job. Best regards.
