Page 78 of 99 FirstFirst ... 68767778798088 ... LastLast
  1. Posts : 72,052
       #770
    Hello Somuch2learn, and welcome to Seven Forums.
    From you log file, it's the KB3068708 update for the same false mismatch issue. Nothing needs to be done. :)
  2. Posts : 3
    KY, Windows 7 Home Premium, 64 Bit
       #771
    Brink, that's reassuring. Thanks for your reply
    I noticed that today you addressed the upgrade to Windows 10 in a separate message. Will the W10 OS installation have the effect of debugging my OS, only making even better? I've had some errors (Windows can't update... code: 80070003) while trying to install "optional" updates to W9.
    You have a gift for clear and concise communication. Thanks again.
  3. Posts : 72,052
       #772
    Upgrading to Windows 10 should sort it since you'll be installing a new Windows. :)
  4. Posts : 4,049
       #773
    MS needs to fix this ...
    MS needs to fix this false positive issue.
    SFC is a great tool in Windows.
    I have no idea how you confirm the validity of system files in Linux.
  5. Posts : 3
       #774
    sfc /scannow vs. Windows Update
    Despite Brink's suggestion that I didn't need to do anything about Update KB3068708, I uninstalled it along with KB3022345 (based on a tip from another WSF thread). I then ran sfc /scannow and got a clean bill of health. This morning Windows Update automatically re-installed KB3068708. Just for grins I re-ran sfc /scannow and got the dreaded "Windows Resource Protection found corrupt files but was unable to fix some of them." This time I will follows Brink's suggestion and do nothing abut Windows 7. After all, later this month we can all start a new learning curve with Windows 10. Good luck out there.
  6. Posts : 13,576
    You have to tutn off auto update.
  7. Posts : 21,482
    Win 7 x64 Home Premium (and x86 VirtualBox VM)/Win10
       #776
    According to MS, these errors are perfectly normal, and can be ignored...
    2015-07-03 16:36:01, Info                  CSI    00000511 [SR] Repairing 1 components
    2015-07-03 16:36:01, Info                  CSI    00000512 [SR] Beginning Verify and Repair transaction
    2015-07-03 16:36:01, Info                  CSI    00000514 [SR] Cannot repair member file [l:24{12}]"utc.app.json" of Microsoft-Windows-Unified-Telemetry-Client, Version = 6.1.7601.18869, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-07-03 16:36:01, Info                  CSI    00000516 [SR] Cannot repair member file [l:66{33}]"telemetry.ASM-WindowsDefault.json" of Microsoft-Windows-Unified-Telemetry-Client, Version = 6.1.7601.18869, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2
    They are the result of MS not actually following their own rules, and tagging the relevant files in the update as 'static' rather than 'variable'.
    You can either:
    1) Uninstall the related update(s) KB3068708 and KB3022345 - and then hide them to prevent reinstall before MS produce a fixed version
    or
    2) ignore them.
    There are no other significant errors in the uploaded file.
  8. Posts : 10,994
    Win 7 Pro 64-bit
       #777
    You can either:
    or
    2) ignore them.
    Noel, I think your option one is the best course of action. If someone merely ignores the updates, runs SFC and gets the "Windows Resource Protection found corrupt files but was unable to fix some of them" notice, there's no easy way to know if the corrupted files are due to the updates or some other system files being corrupted.
    I think Microsoft owes it to consumers who are running Windows 7 to correct this issue.
  9. Posts : 21,482
       #778
    I totally agree - especially since these two updates are far from being 'critical'!
  10. Posts : 1,944
    Windows 10 Home 64-bit
       #779
    How do I find out which files are corrupt, and how to fix them?
