#780
Hello Jesse,
You can do so by running a SFC scan using OPTION TWO, then use OPTION THREE to create a sfcdetails.txt file to see the log file. :)
Hello Jesse,
I don't know how to create a sfc.details.txt. How do I do that?
No problem. Option Three in the tutorial will show you how to step by step. :)
Brink, when I enter that text in the command prompt, it keeps saying "The system path cannot find the path specified".
I entered this text in the command prompt "findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt".
In that case, it sounds like it may be an error made when entering the command.
Did you copy and paste the command?
Yes, I copied and pasted the command.
Give the command below a try to see if it may work, to see if it may be an issue with your environmental variables. :)
findstr /c:"[SR]" C:\Windows\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
If you still get the error, then verify if you have the folder below.
C:\Windows\Logs\CBS
I still received the error. However, when I typed in C:\Windows\Logs\CBS, I got a folder that says CBS and a Text Document that says CBS/CBS.
Ok. Test to see if this below opens your Desktop folder without error.
If so, try copying and pasting the command below one more time.
What place do I enter %userprofile%\Desktop at?
