Page 79 of 99 FirstFirst ... 69777879808189 ... LastLast
  1. Posts : 71,959
       #780
    Hello Jesse,
    You can do so by running a SFC scan using OPTION TWO, then use OPTION THREE to create a sfcdetails.txt file to see the log file. :)
  2. Posts : 1,944
    Windows 10 Home 64-bit
       #781
    I don't know how to create a sfc.details.txt. How do I do that?
  3. Posts : 71,959
       #782
    No problem. Option Three in the tutorial will show you how to step by step. :)
  4. Posts : 1,944
       #783
    Brink, when I enter that text in the command prompt, it keeps saying "The system path cannot find the path specified".
    I entered this text in the command prompt "findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt".
  5. Posts : 71,959
       #784
    In that case, it sounds like it may be an error made when entering the command.
    Did you copy and paste the command?
  6. Posts : 1,944
       #785
    Yes, I copied and pasted the command.
  7. Posts : 71,959
       #786
    Give the command below a try to see if it may work, to see if it may be an issue with your environmental variables. :)
    findstr /c:"[SR]" C:\Windows\Logs\CBS\CBS.log >"%userprofile%\Desktop\sfcdetails.txt"
    If you still get the error, then verify if you have the folder below.
    C:\Windows\Logs\CBS
  8. Posts : 1,944
       #787
    I still received the error. However, when I typed in C:\Windows\Logs\CBS, I got a folder that says CBS and a Text Document that says CBS/CBS.
  9. Posts : 71,959
       #788
    Ok. Test to see if this below opens your Desktop folder without error.
    If so, try copying and pasting the command below one more time.
  10. Posts : 1,944
       #789
    What place do I enter %userprofile%\Desktop at?
