Page 81 of 99 FirstFirst ... 71798081828391 ... LastLast
  1. Posts : 1,944
    Windows 10 Home 64-bit
       #800
    It's still saying the same error. I copied the CBS.log text file to my desktop, and its still giving an error.
  2. Posts : 72,050
       #801
    In that case ZIP the CBS.log on your desktop, and upload the ZIP file here. I'll be happy to take a look at it. :)
  3. Posts : 1,944
       #802
    Sorry, Brink. I went out of town with the family tonight, and we are just now getting in. But, below is ZIPPED Folder with the CBS log in it.
  4. Posts : 72,050
       #803
    Jesse,
    You mistakenly zipped a shortcut to the CBS.log file instead of the actual log file.
    After you copy and paste the C:\Windows\CBS\CBS.log file to your desktop, zip that, then upload it. :)
  5. Posts : 1,944
       #804
    I don't understand! Either that, or what I am doing is not working.
  6. Posts : 1,944
       #805
    Whenever I try to do that, it says Compressed (zipped) Folders Error that then says File not found or no read permission.
  7. Posts : 72,050
       #806
    It sounds like you are trying to ZIP it directly in your "C:\Windows\CBS" folder. That won't work if so.
    You will have to copy the CBS.log file from the CBS folder to your desktop first. Afterwards, ZIP the file on your desktop instead.
  8. Posts : 1,944
       #807
    Brink, so what do I do now?
  9. Posts : 72,050
       #808
    Just what I posted above to ZIP the correct file, and upload it. :)
  10. Posts : 1,944
       #809
    I tried that, and it didn't work.
