Page 82 of 99 FirstFirst ... 72808182838492 ... LastLast
  1. Posts : 72,058
       #810
    What didn't work?
    You should be able to copy the CBS.log file to your desktop. The first time, you just made a mistake and created a shortcut of it instead of copying and pasting it to your desktop.
  2. Posts : 1,944
    Windows 10 Home 64-bit
       #811
    I think I am doing something wrong. Maybe, I need to post a screenshot of what I am doing.
  3. Posts : 1,944
       #812
    I am trying to upload it, but it's synced with my Adobe Creative Cloud. Therefore, I think that's causing it a while to upload.
  4. Posts : 1,944
       #813
    Brink, it's not wanting to upload. It's taking it too long to upload.
  5. Posts : 72,058
       #814
    Did you ZIP it?
  6. Posts : 1,944
       #815
    Yes, it's zipped. But, for some reason, it's having trouble uploading. I have checked it, and it's not a shortcut file. It's a text document file.
  7. Posts : 1,944
       #816
    It will only upload a shortcut document.
  8. Posts : 1,944
       #817
    It says CBS.zip: Your file of 15.16 MB bytes exceeds the forum's limit of 8.00 MB for this filetype.
  9. Posts : 1,944
       #818
    These are the screenshots of the CBS log.
  10. Posts : 1,944
       #819
    Maxie and Brink, see if you all can read this.
    SFC /SCANNOW Command - System File Checker Attached Files
