Page 83 of 99 FirstFirst ... 73818283848593 ... LastLast
  1. Posts : 18,415
    windows 7 home 64bit
       #820
    It is a short cut no Files included Jesse ...
  2. Posts : 1,944
    Windows 10 Home 64-bit
       #821
    I know. I can't figure out how to make it a text document, instead of a shortcut. Sorry for the lack of knowledge.
  3. Posts : 1,944
       #822
    I think I figured it out now. Here it is.
    SFC /SCANNOW Command - System File Checker Attached Files
  4. Posts : 72,050
       #823
    Jesse,
    Yep, that one made it through correctly.
    Good news. The only thing showing up in your SFC log is the false mismatch from KB3068708. There is nothing that needs to be done. :)
  5. Posts : 1,944
       #824
    Okay. Thanks for your help.
  6. Posts : 72,050
       #825
    You're most welcome Jesse. :)
  7. Posts : 10,994
    Win 7 Pro 64-bit
       #826
    Jesse, just some added info about KB3068708.
    This update introduces the Diagnostics and Telemetry tracking service to existing devices. By applying this service, you can add benefits from the latest version of Windows to systems that have not yet upgraded. The update also supports applications that are subscribed to Visual Studio Application Insights.
    Source: https://support.microsoft.com/en-us/kb/3068708
    Unless you absolutely need this update you can uninstall and hide. Future System Files Checker scans should come back clean (no integrity violations found.) IMHO if an update gives a false report of corrupted system files, it will be very difficult to determine if an important system file really is corrupt.
  8. Posts : 1,944
       #827
    So, do I remove the update?
  9. Posts : 72,050
       #828
    You don't need to Jesse. It will not affect SFC from being able to repair your system files.
  10. Posts : 1,944
       #829
    Okay. Thanks for your help, Brink, Maxie, and marsmimar.
