Page 84 of 99 FirstFirst ... 74828384858694 ... LastLast
  1. Posts : 2
    Win 8.1 Pro WMC
       #830
    Please help!!!
    SFC /SCANNOW Command - System File Checker Attached Files
  2. Posts : 72,050
       #831
    Hello Namgostudy, and welcome to Seven Forums. :)
    You have nothing to worry about. Your SFC details show that you only have the false hash mismatch related to the KB3068708 update. You are good.
    See the blue note box at the top of the tutorial for more details.
  3. Posts : 2
    Win 8.1 Pro WMC
       #832
    Thank you so much
  4. Posts : 72,050
       #833
    You're most welcome. :)
  5. Posts : 30
    Windows 7 32 Bit
       #834
    Few questions forgive me if they are answered.
    1: how to identify the files that are corrupt?
    2: if sfc cannot repair them how to repair them?
    3: any tool which helps in aiding this process?
    4: this article mentions using surt. Does it matters of i have sp1? Or sp1 with latest updates installed? As I had used it only for issues when installing sp1. So i think it's pretty old now..? Our its useful even in system where sp1 is already installed
  6. Posts : 72,050
       #835
    Hello bhar,
    Using OPTION THREE to see your sfcdetails.txt will help. :)
  7. Posts : 30
    Windows 7 32 Bit
       #836
    Brink said:
    Hello bhar,
    Yes using that findstr I was able to get know of problematic files. What about other issues raised above?
    Thanks for your quick response.
  8. Posts : 72,050
       #837
    Anytime.
    The items listed in the blue note box at the bottom of OPTION TWO can help. It includes links with more details. :)
  9. Posts : 160
    Win 7 64 bit, 6.1.7601 Service Pack 1 Build 7601
       #838
    Thanks for this tutorial. I followed your steps. I am doing SFC /scannow using win7 repair disc, because I have booting issue.
    This command returns
    "There is a system repair pending which requires reboot to complete. Restart
    windows and run sfc again. I ran couple of times. I am getting the same
    message."
    How do I proceed with SFC /SCANNOW ?
    Thanks for helping.
  10. Posts : 72,050
       #839
    Hello MDRI,
    When it's stuck like that, you could run the command below in a command prompt at boot. When it's finished, try running SFC again. :)
    dism.exe /image:C:\ /cleanup-image /revertpendingactions
