Page 88 of 99 FirstFirst ... 78868788899098 ... LastLast
  1. Posts : 3
    Windows 7 Pro x64
       #870
    The sfcdetails.txt file just repeats those same lines over and over. I fear it will not be much help. Nevertheless, it is attached.
    [Edit]
    There's no need to delete the log files unless you just wanted to. They will be automatically recreated as items are logged again.
    I need to get rid of them if possible. This is on a 250 GB SSD which is now nearly full. Is it safe to delete these files? I'd also like to figure out what's causing them to be so large. Will they come back if I delete them?
    SFC /SCANNOW Command - System File Checker Attached Files
  2. Posts : 72,050
       #871
    Everything looks good in your SFC details with no issues.
    It's normal for these logs to get large. They will eventually overwrite themselves when they reach their max size.
    If you like you can run Disk Cleanup to help with them as well.
  3. Posts : 3
    Windows 7 Pro x64
       #872
    Thank you so much! Last question: I can just delete the entire contents of the CBS folder correct? Or do I need to keep CBS.log?
  4. Posts : 72,050
       #873
    I wouldn't mess with it since it's a protected OS file, and would involve taking ownership to be able to delete it. Besides that, it would also just be recreated and still get logged to as needed by Windows.
  5. Posts : 235
    Windows 10 Pro Version 22H2 64-bit Edition
       #874
    thank you very much
    Thank you for taking youre time, Instruct us step by step
    I enjoy to see tutorials with images included, made me feel more secure, and knowing what am doing its's always a plus!!
    Thanks again!
  6. Posts : 235
       #875
    Hi, it's everthing Okay?
    I have review .txt.. and everything looks good, or what should I look for?
    thank you ver much for review this attachment!
  7. Posts : 72,050
       #876
    Hello squirtmph, :)
    Looking at your SFC details, it looks like you added group policy to your Home Premium edition. If so, that would be why these files are showing with a hash mismatch.
    2015-10-28 15:17:14, Info                  CSI    0000064c [SR] Beginning Verify and Repair transaction
    2015-10-28 15:17:15, Info                  CSI    0000064e [SR] Cannot repair member file [l:22{11}]"fdeploy.dll" of Microsoft-Windows-fdeploy, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:15, Info                  CSI    00000650 [SR] Cannot repair member file [l:14{7}]"fde.dll" of Microsoft-Windows-fde, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:16, Info                  CSI    00000652 [SR] Cannot repair member file [l:14{7}]"fde.dll" of Microsoft-Windows-fde, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:16, Info                  CSI    00000653 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
    2015-10-28 15:17:16, Info                  CSI    00000656 [SR] Could not reproject corrupted file [ml:48{24},l:46{23}]"\??\C:\windows\SysWOW64"\[l:14{7}]"fde.dll"; source file in store is also corrupted
    2015-10-28 15:17:18, Info                  CSI    00000664 [SR] Cannot repair member file [l:22{11}]"fdeploy.dll" of Microsoft-Windows-fdeploy, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:18, Info                  CSI    00000665 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
    2015-10-28 15:17:18, Info                  CSI    00000668 [SR] Could not reproject corrupted file [ml:48{24},l:46{23}]"\??\C:\windows\SysWOW64"\[l:22{11}]"fdeploy.dll"; source file in store is also corrupted
    2015-10-28 15:17:18, Info                  CSI    0000066a [SR] Verify complete
    2015-10-28 15:17:18, Info                  CSI    0000066b [SR] Verifying 100 (0x0000000000000064) components
    2015-10-28 15:17:18, Info                  CSI    0000066c [SR] Beginning Verify and Repair transaction
    2015-10-28 15:17:19, Info                  CSI    0000066e [SR] Cannot repair member file [l:20{10}]"gpedit.dll" of Microsoft-Windows-GroupPolicy-Admin-Gpedit, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:21, Info                  CSI    00000670 [SR] Cannot repair member file [l:20{10}]"gptext.dll" of Microsoft-Windows-GroupPolicy-Gptext, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:23, Info                  CSI    00000672 [SR] Cannot repair member file [l:20{10}]"gptext.dll" of Microsoft-Windows-GroupPolicy-Gptext, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:23, Info                  CSI    00000673 [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
    2015-10-28 15:17:23, Info                  CSI    00000676 [SR] Could not reproject corrupted file [ml:48{24},l:46{23}]"\??\C:\windows\SysWOW64"\[l:20{10}]"gptext.dll"; source file in store is also corrupted
    2015-10-28 15:17:23, Info                  CSI    00000679 [SR] Cannot repair member file [l:20{10}]"gpedit.dll" of Microsoft-Windows-GroupPolicy-Admin-Gpedit, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2015-10-28 15:17:23, Info                  CSI    0000067a [SR] This component was referenced by [l:202{101}]"Microsoft-Windows-Foundation-Package~31bf3856ad364e35~amd64~~6.1.7601.17514.WindowsFoundationDelivery"
    2015-10-28 15:17:23, Info                  CSI    0000067d [SR] Could not reproject corrupted file [ml:48{24},l:46{23}]"\??\C:\windows\SysWOW64"\[l:20{10}]"gpedit.dll"; source file in store is also corrupted
    2015-10-28 15:17:24, Info                  CSI    00000680 [SR] Verify complete
  8. Posts : 235
       #877
    Thank you!
    I will say this is a good sign! right?, Now back to you stamen/post what this mean to me, me?
    thanks for you quick response
  9. Posts : 72,050
       #878
    You're welcome. :)
    I'd say you have nothing to worry about for the SFC results if you did add group policy.
  10. Posts : 235
       #879
    Question
    How could I check up, If I have?
    I almost miss your post, but thank for get back to my concern, If there is a way to me to found out this policy, could you be available to pint point to me, please?
