Page 89 of 99 FirstFirst ... 798788899091 ... LastLast
  1. Posts : 17,322
    Win 10 Pro x64
       #880
    squirtmph said:
    How could I check up, If I have?
    I almost miss your post, but thank for get back to my concern, If there is a way to me to found out this policy, could you be available to pint point to me, please?
    Normally, you don't have that feature, it is for Pro and above.
    There are ways on the internet to enable that feature in the lower versions.
    You would know if you enabled it, it would be a deliberate action.
  2. Posts : 235
    Windows 10 Pro Version 22H2 64-bit Edition
       #881
    Thank you very much! have great dinner time \w/
  3. Posts : 7
    Windows 7 Home Premium 64-bit
       #882
    sfc difficulty
    hi,
    I'm having some PC issues. Tried running SFC as instructed.
    See uploaded pic.
    I attempted to export to sfcdetails.txt but came up with an empty text file
    Thank you!
    Attached Thumbnails Attached Thumbnails SFC /SCANNOW Command - System File Checker-sfc-verify.png
  4. Posts : 72,046
       #883
    Hello DocPT, :)
    See if running a SFC /SCANNOW command instead may give you results.
  5. Posts : 7
       #884
    ok got this the next time
    that was with sfc /scannow
    SFC /SCANNOW Command - System File Checker Attached Files
  6. Posts : 21,482
    Win 7 x64 Home Premium (and x86 VirtualBox VM)/Win10
       #885
    You have some issues in the background there which need to be dealt with in another way -
    Please download and save the CheckSUR tool from http://support.microsoft.com/kb/947821
    (you'll need to look in the details for Windows 7, downloading from the Microsoft Download Center)
    Run it - The tool can take anywhere from 5 mins to a couple of hours to run (or 'Install') depending on how much it has to do, and may exit silently - it may appear to freeze for most of that time, but be patient.
    The result is logged in the C:\Windows\Logs\CBS\CheckSUR.log file - and an archive …\checksur.persist.log file
    Then zip the CheckSUR.log and upload it to your reply.
  7. Posts : 7
       #886
    thanks NoelDP
    here is the zip file
  8. Posts : 21,482
       #887
    Here's the Summary from the log...
    Summary:
    Seconds executed: 826
     Found 40 errors
     Fixed 20 errors
      CSI Manifest Missing Total count: 9
      Fixed: CSI Manifest Missing.  Total count: 2
      CSI Catalog Missing Total count: 4
      Fixed: CSI Catalog Missing.  Total count: 4
      CSI Payload File Missing Total count: 17
      Fixed: CSI Payload File Missing.  Total count: 7
      CBS MUM Missing Total count: 2
      CBS Catalog Missing Total count: 1
      CSI Store Directory Missing Total count: 7
      Fixed: CSI Store Directory Missing.  Total count: 7
    Unavailable repair files:
    	winsxs\manifests\amd64_microsoft-windows-d..fontcache.resources_31bf3856ad364e35_7.1.7601.16492_ko-kr_f255f071e2bad917.manifest
    	winsxs\manifests\amd64_netfx-cvtresui_dll_b03f5f7f11d50a3a_6.1.7601.22733_none_477b4e67da3fc938.manifest
    	winsxs\manifests\x86_microsoft-windows-p..age-codec.resources_31bf3856ad364e35_7.1.7601.16492_nl-nl_5babb207a1b28455.manifest
    	winsxs\manifests\amd64_microsoft-windows-u..oyment-languagepack_31bf3856ad364e35_7.1.7601.16492_sl-si_596761acf46f970c.manifest
    	winsxs\manifests\amd64_microsoft-windows-d..fontcache.resources_31bf3856ad364e35_7.1.7601.16492_nb-no_dae871a6bae004d3.manifest
    	winsxs\manifests\amd64_win7-microsoft-wind..oyment-languagepack_31bf3856ad364e35_7.1.7601.16492_sl-si_55b44dcdf47b38b7.manifest
    	winsxs\manifests\amd64_win7-microsoft-wind..oyment-languagepack_31bf3856ad364e35_7.1.7601.16492_sl-si_1c113d91e8b4627d.manifest
    	servicing\packages\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.mum
    	servicing\packages\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.mum
    	servicing\packages\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.mum
    	servicing\packages\Win8IP-Microsoft-Windows-DownlevelApisets-Com-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat
    	servicing\packages\Win8IP-Microsoft-Windows-DownlevelApisets-Base-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat
    	servicing\packages\Win8IP-Microsoft-Windows-DownlevelApisets-WinIP-Package~31bf3856ad364e35~amd64~uk-UA~7.1.7601.16492.cat
    I'll post a fix protocol for these errors when I can find the time!
  9. Posts : 21,482
       #888
    I've uploaded a file - dptaa.zip - to my OneDrive at Noel's OneDrive
    Please download and save it.
    Right-click on the downloaded file, and select Extract all…
    Extract to the default location - which will create a new folder dptaa in the same place.
    Open this folder - there should be two folders inside it (Manifests, and Packages)
    Copy the content of the Packages folder to the folder
    C:\Windows\Temp\CheckSur\Servicing\Packages
    And the content of the manifests folder (.manifest files) into this folder:
    C:\Windows\Temp\CheckSur\Winsxs\Manifests
    Now run the CheckSUR tool again (it may take a while)
    Post the new CheckSUR.log file, and the CheckSUR.persist.log file.
    Then run another SFC /SCANNOW and post the new CBS.log file
  10. Posts : 7
       #889
    NoelDP
    Thanks for putting that together!
    I attached the new logs.
