Page 91 of 99 FirstFirst ... 818990919293 ... LastLast
  1. Posts : 2
    Windows 7 Pro 64-bit
       #900
    Hello. Attached is my sfcdetails.txt file. Iam not sure how to read it. It looks to me that the only "corrupted" files are windows fonts but I am note sure. I did uninstall many windows fonts that I will never use. If that is all there is then I would think I am okay. Can someone take a look at the file and let me know if I haveto do a repair? Thanks.
    SFC /SCANNOW Command - System File Checker Attached Files
  2. Posts : 72,046
       #901
    Hello Spartacii, :)
    It looks like SFC had found and repaired some corrupted fonts, but you're good to go now.
  3. Posts : 132
    Dual boot - Win 7 Pro 64-bit and Win 10 Pro 64-bit
       #902
    brink - I've forgotten what is recommended for Win 7 like DISM that works in Win 10 (but not 7). Can't find it. The Win 7 command is related to an image command.
    Please re-post that command. Thanks.
  4. Posts : 72,046
       #903
    Hello glnz, :)
    Here you go.
    https://support.microsoft.com/en-us/kb/947821
  5. Posts : 4
    I ran SFC 4 times in a row and it wasn't able to fix all issues.
    I attached the sfcdetails.txt file in case someone is willing to help me troubleshoot the issues.
    Thanks in advance. :)
  6. Posts : 72,046
       #905
    Hello mobilebyrd, and welcome to Seven Forums. :)
    You have the Windows 7 update (KB3022345) causing corrupt files issue. The link below can help show you how to fix this.
    The Tech Cookbook – Windows 7 update (KB3022345) causing corrupt files
  7. Posts : 7,107
       #906
    3022345
    Hi Mobilebyird,
    Follow this link same problem.
    Windows Update error code 643
    Roy
    You beat me Brink:)
  8. Posts : 4
    Thanks Brink. I'm creating a restore point before attempting the repairs outlined in your link. I'll report back once I'm done.
  9. Posts : 4
    Thank you both for your replies.
    I followed the steps as outlined on the other page and the last scan came back with no errors.
    Once again, thank y'all very much.
  10. Posts : 72,046
       #909
    You're most welcome. Glad we could help. :)
