Page 93 of 99 FirstFirst ... 839192939495 ... LastLast
  1. Posts : 5
    Thank you so much for the tutorial and advice! Everything seems ok now!
  2. Posts : 72,059
       #921
    Great news.
  3. Posts : 4
    Windows 7 Home Premium
       #922
    I am having the "Windows Explorer has stopped working" problem. Tried all the recommended solutions to no avail. Ran sfc \scannow and got the message that some files could not be repaired. Moved the sfcdetails to my desktop per instructions but I get "Access denied" message when try to access the file. I am running Windows 7 in Administrator Mode. Any suggestions?
  4. Posts : 72,059
       #923
    Hello herbtr8, and welcome to Seven Forums. :)
    You might see if using the tutorial below to take ownership of the file may allow you to access it afterwards.
    Take Ownership Shortcut
  5. Posts : 4
       #924
    Thanks for your help, I now have over 800 pages of the CBS.LOG file and don't know how to find my corrupt files, Any suggestions?
  6. Posts : 72,059
       #925
    You can use OPTION THREE in the tutorial on the first page to create a sfcdetails.txt file to only see the SFC results. :)
  7. Posts : 4
       #926
    Thanks again. Here is a portion of the sfcdetails.txt showing errors. How do I interpret it and repair?
    2016-05-02 13:52:30, Info CSI 00000445 [SR] Cannot repair member file [l:78{39}]"Api-ms-win-downlevel-version-l1-1-0.dll" of Microsoft-Windows-Application-Experience-Inventory, Version = 6.1.7601.23412, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2016-05-02 13:52:31, Info CSI 00000447 [SR] Cannot repair member file [l:78{39}]"Api-ms-win-downlevel-version-l1-1-0.dll" of Microsoft-Windows-Application-Experience-Inventory, Version = 6.1.7601.23412, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
    2016-05-02 13:52:31, Info CSI 00000448 [SR] This component was referenced by [l:152{76}]"Package_3_for_KB2952664~31bf3856ad364e35~x86~~6.1.17.5.2952664-5_neutral_LDR" 2016-05-02 13:52:32, Info CSI 0000044a [SR] Could not reproject corrupted file [ml:520{260},l:66{33}]"\??\C:\Windows\System32\CompatTel"\[l:78{39}]"Api-ms-win-downlevel-version-l1-1-0.dll"; source file in store is also corrupted
    2016-05-02 13:52:32, Info CSI 0000044c [SR] Repair complete 2016-05-02 13:52:32, Info CSI 0000044d [SR] Committing transaction
    2016-05-02 13:52:33, Info CSI 00000451 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
  8. Posts : 72,059
       #927
    From the Microsoft link below, you're not alone with this "Api-ms-win-downlevel-version-l1-1-0.dll" file issue.
    http://answers.microsoft.com/en-us/w...a-c61300efaf93
    Considering your other issues, you might see if doing a system restore at boot using a restore point dated before you had all these issues may help.
    System Restore
  9. Posts : 4
       #928
    Thanks for all your help After reading about and researching the "Api-ms-win-downlevel-version-l1-1-0.dll" file issues, I think I will live with it until I upgrade to Windows 10. Also, I think I have had this problem for several months and don't know which restore point to choose. Hopefully MS will address this issue since it appears they are at fault. Thanks again
  10. Posts : 72,059
       #929
    You're most welcome.
