Page 97 of 99 FirstFirst ... 879596979899 LastLast
  1. Posts : 13
    Windows 7 Home Premium 64 bit
       #960
    Re: Windows Resource Protection unable fix some corrupt files
    Thank you Brink, Snick & NoelDP
    First in response to Brink
    Checked Device Manager - default view (Devices by type). No entries were expanded out (which would have yellow exclamation points), then on View menu, checked "Show hidden devices", found "Non-Plug and Play Drivers" expanded out with yellow exclamation point on "aoddriver" which refers to "aoddriver2.sys which if I'm not mistaken is the AMD Fuel Overdrive driver
    Ran "eventvwr.msc" Expanded out "Windows Logs" to "System", scrolled down through events and found an "Error" with red exclamation point, Source - Service Control Manager, Event ID - 7000 :
    The AODDriver4.1 service failed to start due to the following error:
    The system cannot find the path specified.
    Searched registry for AODDriver4.1 entry. Found at :
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\AODDriver4.1]
    and
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\AODDriver4.1]
    and
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\services\AODDriver4.1]
    The Value data for the ImagePath Value name for all three entries is:
    \??\C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys
    That folder, subfolders and file no longer exist. The wrong version of AMD Catalyst drivers (which included the Overdrive driver) were installed by mistake and then uninstalled late last year and evidently left an orphan in the registry.
    In response to NoelDP
    Thank you for your thoughts regarding .NET I am also not very good at repairing .NET
    In response to SNICK
    Thank you for your evident expertise with this issue.
    I downloaded and ran SURTx64. I have attached the CheckSUR.log
    Thanks to all of you for your help.
    admjgreer
    SFC /SCANNOW Command - System File Checker Attached Files
  2. Posts : 72,052
       #961
    AODDriver4.1 is for AMD Overdrive, but I don't think this is related to the issue found by SFC.
    If you don't use it, you could uninstall it.
    If you do, then you could see if reinstalling the latest version may help.
    OverDrive™ Technology to Overclock CPU and Fan Control | AMD
  3. Posts : 3,615
       #962
    @admjgreer
    Would you please post cbs folder, if its over 8 MB you'll have to upload it to a cloud storage service. Limit here 8.95 MB zip, 8.0 MB rar.
  4. Posts : 3,615
       #963
    Well, admjgreer, only had one of your manifests, had to sleuth the others!
    Please download CheckSUR.zip extract CheckSUR folder and paste to: C:\Windows\Temp
    Run SURT again, when it completes, post CheckSUR.log and CBS.log both at: C:\Windows\Logs\CBS
  5. Posts : 13
       #964
    Snick
    My CBS folder is 56 MB.
    I don't use a cloud service as I have not needed one.
    Will the cbs.log and checksur.log suffice ?
    cbslog.zip and checksur.log are attached.
    admjgreer
  6. Posts : 13
       #965
    Snick
    Attached screenshot of CBS folder. If you don't need all of the files, tell me which ones you need.
    admjgreer
    Attached Thumbnails Attached Thumbnails SFC /SCANNOW Command - System File Checker-cbs-folder.jpg
  7. Posts : 3,615
       #966
    Yes, those two for now thank you, hopefully the cbs.log will go back far enough.
  8. Posts : 13
       #967
    Hi Snick
    How's it going? Do you need any more information? I'll bet you're buried with work.
    Thank you again for your help.
    admjgreer
  9. Posts : 3,615
       #968
    admjgreer
    Sorry, yes busy...
    Could you post your CBS folder including CBS.Persist.cab files please.
    Upload limit here is 8 MB for zip/compressed folder.
    You'll have to use OneDrive, Google Drive, Dropbox, A-Drive, i.e. a cloud storage site.
  10. Posts : 13
       #969
    Thanks SnickI'll be out of town till Saturday May 4.
    Will get back to it after then.
    admjgreer
