Show - Hide Hidden Files - Add to Context Menu
Page 7 of 8 FirstFirst ... 5678 LastLast
  1. Posts : 72,050
       #60
    M18XR2 said:
    "Show" or "Don't show" hidden files, folders, drives, and protected operating system files
    thats the ability of the added context menu. however is it possible to have some of these functions on a separate menu? If possible I'd like to see show hidden files separate from show protected operating system files.. wondering if thats possible
    Ok M18XR2. The tutorial has been updated to be able to have one or both options available now.
    To update, remove the current context menu, and use the new downloads in the tutorial. :)
  2. Posts : 71
    window 7 64 bit
       #61
    hey Brink, I tried it but it only has show all hidden files, just like the old one
    where cfan i get the new downloads?
    Edit: nevermind I see what you mean. it is working very nicely this is what I wanted. thank you once again man
  3. Posts : 72,050
       #62
    You're most welcome. :)
  4. Posts : 20
    Windows 7 Home Premium 64-bit SP1
       #63
    I hope this isn't asking too much , but would you be a dear and add the final combination: context menu to toggle only "protected operating system files"? Please?
  5. Posts : 72,050
       #64
    Hello Soyabeaner,
    I wish I could, but in order for protected OS files to show, the Show hidden files, folders, and drives option must be turned on (checked) as well.
  6. Posts : 20
       #65
    Fair play.
  7. Posts : 14
    None
       #66
    Thank you very much! That's what I've been looking for! SevenForums and you rockz!
  8. Posts : 83
    Microsoft Windows 7 64-bit Service Pack 1
       #67
    For some reason, I keep getting the shield icon on the Show/Hide Hidden Files but not on the Show/Hide All Hidden Files. Attached is a picture of my context menu.
    Attached Thumbnails Attached Thumbnails Show - Hide Hidden Files - Add to Context Menu-untitled.jpg
  9. Posts : 72,050
       #68
    Hello TON, :)
    The .reg file below will remove the UAC shield for you.
    Show - Hide Hidden Files - Add to Context Menu Attached Files
  10. Posts : 83
       #69
    Brink said:
    Hello TON, :)
    Thank you so much! Happy New Year!
