Show - Hide Hidden Files - Add to Context Menu
Page 8 of 8 FirstFirst ... 678
  1. Posts : 72,059
       #70
    You're most welcome TON. I hope have a Happy New Year as well. :)
  2. Posts : 17
    windows 10 32bit
       #71
    Num lock msg tirggered
    Hi Shawn,
    This works great but everytime it shows/hides the files and folders the "numlock on" msg is triggered, im not sure why, i have logitech setpoint installed for my wireless keyboard and mouse...the script somehow interferes with them and displaying the numlock on msg, is there any way i can disable that?
  3. Posts : 72,059
       #72
    Hello Joseph, :)
    As a test, do you see the "numlock on" message if you press F5 (refresh) the desktop?
    That's the only thing in the .vbs file I see that may possibly be causing this with the Logitech software. The rest of the commands are only changing registry values for hide/show.
  4. Posts : 17
    windows 10 32bit
       #73
    Brink said:
    Hello Joseph, :)
    Thanks for the reply,
    No I dont see the Num lock message shown when i press F5 normally..only when i click the show files right click menu it happens...
    Its not a big deal anyway..:)
  5. Posts : 72,059
       #74
    Odd little issue.
  6. Posts : 17
    windows 10 32bit
       #75
    Brink said:
    Odd little issue.
    Yes, If you see the attachments the logitech software is showing the tooltip as "Num lock On" and if we turn off the settings inside the software(attch 2) then the message is not shown....but I would like to have this message shown..
    Attached Thumbnails Attached Thumbnails Show - Hide Hidden Files - Add to Context Menu-1.jpg   Show - Hide Hidden Files - Add to Context Menu-2.jpg
  7. Posts : 17
    windows 10 32bit
       #76
    Possible to add Keyboard shortcut for this?
    Hi Shawn,
    As days goes by this is the only script I use it daily...Is there a way to add a keyboard shortcut instead of right click and click "show all hidden files" ?
  8. Posts : 72,059
       #77
    josephkarthic said:
    Hi Shawn,
    Hello Joseph,
    You could create a shortcut of the VBS file on the desktop, in the Start menu, or pinned to the taskbar or Start menu.
    Afterwards, assign a keyboard shortcut like below to this VBS shortcut to use.
    Keyboard Shortcut | Vista Forums
  9. Posts : 17
    windows 10 32bit
       #78
    Brink said:
    Hello Joseph,
    Wow..You are a Genius ..Thankyou..
  10. Posts : 72,059
       #79
    You're most welcome.
