#70
You're most welcome TON. I hope have a Happy New Year as well. :)
Hi Shawn,
This works great but everytime it shows/hides the files and folders the "numlock on" msg is triggered, im not sure why, i have logitech setpoint installed for my wireless keyboard and mouse...the script somehow interferes with them and displaying the numlock on msg, is there any way i can disable that?
Hello Joseph, :)
As a test, do you see the "numlock on" message if you press F5 (refresh) the desktop?
That's the only thing in the .vbs file I see that may possibly be causing this with the Logitech software. The rest of the commands are only changing registry values for hide/show.
Hi Shawn,
As days goes by this is the only script I use it daily...Is there a way to add a keyboard shortcut instead of right click and click "show all hidden files" ?
Hello Joseph,
You could create a shortcut of the VBS file on the desktop, in the Start menu, or pinned to the taskbar or Start menu.
Afterwards, assign a keyboard shortcut like below to this VBS shortcut to use.
Keyboard Shortcut | Vista Forums
