Folder View Settings - Reset All to Default
Page 5 of 5 FirstFirst ... 345
  1. Posts : 4
    Windows 10 Pro 64-bit
       #40
    Brink said:
    Hello Bruno, and welcome to Seven Forums. :)
    Here you go:
    Reset Folder View Settings to Default in Windows 10 Windows 10 Tutorials
    Thanks Brink, but I need a more specific script. I want to reset the window position (X, Y) of the applications. Can you help me? Thanks!
  2. Posts : 72,078
       #41
    Usually explorer will open in the same position it was last closed.
  3. Posts : 4
       #42
    Yep! and I want to reset it and my applications to the default position, like a fresh install of Windows...
  4. Posts : 72,078
       #43
    Resetting explorer using the .bat file in the tutorial below for Windows 10 will also reset the position of File Explorer back to default.
  5. Posts : 4
       #44
    I need to reset not only the File Explorer, but the position of all applications. There's a way?
    Something like this.
    Thanks!
  6. Posts : 72,078
       #45
    I'm not aware of a universal reset position for all apps option. Plus, not all apps can have their position reset.
    If this is something you need often, then you might consider if a guest account may work for you where everything is reset to default after each session.
    Add Guest Account in Windows 10 Windows 10 Tutorials
  7. Posts : 1
    Windows 7 Home Premium SP1 64 bit
       #46
    Harry in Marietta GA.
    Brink, you have created a masterpiece of code. Thank you!
    I have been using this Dell XPS8500 with Windows 7 since December 2012. I used the "reset Windows Explorer" to look at the Packing Slip which is the last file in my downloads.
    Last week, I encountered the woes of Windows Explorer when I did something that really scrambled the views of my file system. That was on Thursday March 4. For 3-4 days, I have searched for a solution. I tried one of your earlier batch files that did not fix things.
    Today I found this solution. When I open Windows Explorer, the view is BEAUTIFUL.
    Thank You!
  8. Posts : 72,078
       #47
    Thank You!
    I'm glad it was able to help, and welcome.
