I'm not sure that I understand the rationale for killing explorer.exe. In my tests, killing explorer like that causes the desktop items to shift to the left. A simple restart would preserve the desktop items' locations.
Is there some concern that multiple explorer instances can be in RAM - and if they are allowed to exit normally, they will write their info to the registry entries that were just cleaned?
If you must keep the explorer kill lines in place, then please warn the user that the desktop items may shift. See this post.
That's correct. If explorer is opened before it is restarted, then it may not be able to fully apply resetting all folder views, and the Computer window may not display in it's default tile view. Restarting explorer is safety measure to make sure that resetting of the folder views is done properly.
It should usually be known that resetting folder views to default and restarting explorer would also realign the desktop icons as well, but I'll add a note for this. :)
Thanks for adding that.
I'm one of those types that keeps over 100 items on the desktop.
I would not have been happy if they all "went left on me" - so to speak
I use the Desktop Restore app to keep things in place and I don't let any accounts write to some of those registry keys once I have them like I like them, so I've not had to reset them. I just did not want to suggest the tut w/o a warning or a work around.
Cool, didn't know a Desktop Restore app existed. Will make rearranging 86 icons on my desktop much easier. Wonder if the app will work for tri-monitor setups.
I have a tendency to over test
Here is what the stored info looks like for items on 8 monitors:
4 monitors at 1024x768 and 4 monitors at 800x600.
I positioned one item on monitors 1 thru 6...
...saved the layout via Desktop Restore
...moved all items to monitor 1
...restored all items via Desktop Restore
It worked just fine.
Notice that the applet records the monitor number* and the X, Y coordinates. I don't know how it restores the items to those coordinates, but it does. I'm not sure what would happen it a monitor was missing during the restore. I'm not sure how to simulate that via Virtual Box.
*monitor number 1 is recorded by this applet as monitor 0
so monitor 5 shown in the screenshot will be monitor #6 in Windows' GUIs.
