Folder Template - Default
Page 2 of 9 FirstFirst 1234 ... LastLast
  1. Posts : 557
    Windows 7 x64 Ultimate SP1
    Brink said:
    Zardoc,
    No need to create a separate tutorial. Adding the TIP box at the top should work just as well. :)
    Be my guest Shawn.
  2. Posts : 72,155
    anykey said:
    Zardoc said:
    Brink I'm not sure if you have this, but if you want to add it to your tutorial, be my guest.
    You can prevent Windows from sniffing folder contents and automatically assigning the folder type template
    [HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\shell]
    "FolderType"="NotSpecified"
    Cheers.
    Ah this sounds like what I want.
    I shall look forward to reading the tutorial.
    esp to know what Windows (7) will do if you tell it to stop "automatically assigning the folder type template".
    At the moment I simply cannot get Windows 7 to display docs in a folder of docs, photos in a folder of photos, and music in a folder of music.
    Hello AnyKey,
    You can read it in the yellow TIP box at the top of this tutorial.
  3. Posts : 124
    Dual boot XP Pro and Seven/7127
       #12
    Brink, thanks for the tip, ha ha.
  4. Posts : 72,155
    You're most welcome.
  5. Posts : 3
    Hey Brink.
    Am I right in thinking that, in order to set it so that every folder opened in explorer will appear in the Details view, I'd have to download each of these individually?
    I'd like my box set up so that, no matter it's contents, any folder opened will open in the Details view.
    Ideally it'd do that regardless of whether I opened Computer or Explorer, but it's not really as issue as I generally only Win+E it.
    This tutorial is what I need to follow, right?
    Edit: Looking at it again, I'm not sure it is. Hmm...
  6. Posts : 72,155
       #15
    Hello Berryman,
    Correct, you can do only step 2 for the "General Items" template for what you want. :)
  7. Posts : 3
    WIndows 7 Ultimate
       #16
    Viewing PDF's and CBR/CBZ files
    I have tons (thousands) of PDF and Comicbook CBR/CBZ files stored in a veritable tree of folders and need to be able to have all folders and subfolders default view in Extra Large icon. But only in certain folders, not all of my folders on my entire computer. How do I do this?
  8. Posts : 72,155
       #17
    Hello Cocktailmunky, and welcome to Seven Forums.
    I'm afraid that you would have to set them to be Extra Large Icons in each folder manually since you only want them in specific ones.
    If you want to apply that to all folders that have a certain folder template (ex: Documents) instead, then you can use this to do so to help as well.
    https://www.sevenforums.com/tutorials...l-folders.html
  9. Posts : 1
    windows 7
       #18
    Anykey....
    I had the same problem. I have my music folders with different mixed music in it. I have pictures files that I used to label all my music folders. With my new PC windows 7 64 bits. I can't change folder picture to what I want.
    I tried the follow steps and it works.
    1. Go to your folder that you want to change picture.
    2. Right click and select "Properties"
    3. Select "Customize" tab
    4. Select "Change Icon"
    5. Select an icon, any icon
    6. Go to "Customize" tab.
    7. Selec "Choose Pictures..." At this point you should be able to pick any picture that you want in your PC.
    8. Select Open it or double clicks on the picture.
    9. Go to "change Icon" and select "restore icon default"
    10. You should have picture on you folder.
  10. Posts : 57
    PC, Windows 7 32 bit
       #19
    Setting column size so it stays set
    Hi Brink,
    Lots of good info here, Sir. You've done a lot of work, and I'm sure everyone appreciates it. I know I do!
    Maybe I'm in the wrong place, but I have a simple thing to learn - how can I keep a folder's size the way I set it (ie., "Size Column to Fit" or "Size All Columns To Fit"?) It seems I set the size and go away and when I return, the size of the column has gone back to what Windows 7 wants it to be, and I have to do the re-size thing again. Is there a way to "glue" the folder columns size after I set it?
    I hope this isn't confusing...
    Thanks, Noel
