Remote Desktop - Set Time Limit for Active Sessions
    How to Set Time Limit for Active Remote Desktop Sessions
    This allows you to specify the maximum amount of time that a Remote Desktop Services session can be active before it is automatically disconnected.
    If a time limit is set, the user receives a warning two minutes before the Remote Desktop Services session disconnects, which allows the user to save open files and close programs.
    If you have a console session, active session time limits do not apply.
    You must be logged in as an administrator to be able to do this tutorial.
       Warning
    While all editions of Vista, Windows 7, and Windows 8 can be a remote desktop client...
    • Only the Vista Business, Ultimate, and Enterprise editions can host a remote desktop connection.
    • Only the Windows 7 Professional, Ultimate, and Enterprise editions can host a remote desktop connection.
    • Only the Windows 8 Pro and Enterprise editions can host a remote desktop connection.
    OPTION ONE
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, Windows Components, Remote Desktop Services, Remote Desktop Session Host, and Session Time Limits. (see screenshot below)
    3. In the right pane, right click on Set time limit for active Remote Desktop Services sessions and click on Edit. (see screenshot above)
    4. To Remove Time Limit for Active Remote Desktop Services Sessions
    A) Select (dot) either Not Configured or Disabled. (see screenshot below step 6)
    B) Go to step 6.
    5. To Set Time Limit for Active Remote Desktop Services Sessions
    A) Select (dot) Enabled. (see screenshot below step 6)
    B) Under Options, click on the Active session limit drop down box and select an amount of time you would like to set as the time limit. (see screenshot below step 6)
    6. Click on OK. (see screenshot below)
    OPTION TWO
    Manually in Registry Editor
    1. Open the Start Menu, then type regedit in the search box and press Enter.
    3. In regedit, navigate to the location below: (see screenshot below)
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\Terminal Services
    4. To Set Time Limit for Active Remote Desktop Services Sessions
    A) In the right pane of Terminal Services, right click on a empty space, click on New and DWORD (32-bit) Value, type MaxConnectionTime and press Enter. (see screenshot below)
    B) In the right pane, right click MaxConnectionTime and click on Modify. (see screenshot above)
    C) Select (dot) Decimal, then type in the registry Value data in the table below for the amount of time you want to set as the time limit and click on OK. (see screenshot below)
    D) Go to step 6.
    5. To Remove Time Limit for Active Remote Desktop Services Sessions
    A) In the right pane, right click MaxConnectionTime and click on Delete. (see screenshot below step 4A)
    B) Click on Yes. (see screenshot below)
    6. Close regedit.
    7. Log off and log on, or restart the computer to apply the changes.
  1. Posts : 1
    10 minutes should read 600000 not 60000
    15 minutes should read 900000 not 90000
  2. Posts : 72,046
    Thank you Richard. Corrected. :)
