USB Driver - General Fix for Problems
Page 4 of 8 FirstFirst ... 23456 ... LastLast
  1. CEM
    Win 7 Ultimate 64
       #30
    THE BEST!!!!
    Pooch, this bsod was driving me CRAZY!!! The usb mouse would disconnect every once in a while and unplugging/plugging back in solved the issue.
    Then all of a sudden, after about 3 s/w installs and MS Updates, the fe error.
    Thought it was the mobo. Then h/w. Uninstalled the new s/w. Nope.
    About to go out and buy new mobo, figuring it was the mouse/keyboard inputs.
    Found this tutorial. Holy Mackerel!!! The number of greyed out usbs was over 30.
    The issue of Admin addition not working is because you have to add Rights to that user; are not automatically granted.
    Thank you pooch, very much.
  2. Posts : 5
    win 7 ultimate
       #31
    hi pooch,
    Help please,
    I have an Imation Usb Flash disk 4GB nano pro,
    everytime I plug in to my Toshiba Laptop A300 using Windows 7
    it says windows update cannot find the driver ,
    so it say usb device not recognized and I cant see it in my Devices with removable storage.
    When i go to device manager, i can see the unknown device as nano pro
    but no driver installed, it has an yellow exclamation mark. tried update driver but failed because Windows 7 cannot find it online.
    When i run Ubuntu OS on the same laptop,
    usb imation is working so i guess theres a problem only with Windows 7 driver or Windows 7 OS .
    I followed your instruction here but still it doesnt work because it doesnt have a driver,
    Also, i tried a different brand usb flash disk and its working, only this Imation brand is not.
    Thanks a lot
  3. Posts : 1
    7 ultimate 32bit 4off
       #32
    Mmmm none of this works for me i have 2 different systems same hardware different mother boards both asus
    1 a p5VD1_X(X-XP3) and a P5bw-LA (x-VISTA) both newdrives to windows 7 ultimate everthing is ok with the P5VD but none of the usb ports internal and external work on the P5BW if i put the vista drive back in all works well so problem is not hardware but is windows seven dose not like my board althoug seven adviser said all was ok.
    All usb ports are live but do not read or write they show in device manager
    I have done all as above but does not work so no need to go back over that!
    ran driver wizard and all drivers are upto date.
    When i compare device manager USB's they are titled different?
    Anyone anyfurther Ideas
  4. Posts : 21
    Window 7 Pro 64 bit
       #33
    For those asking about how to delete the infcache.1 file, I deduced after adding administrators it would be necessary to check the boxes regarding permissions.
  5. Posts : 1
    Windows 7 home premium 32bit
       #34
    My system has been freezing a lot so this looked like a good option. I do not have a wired mouse so had to use a USB version. Have restarted the computer but none of the USB ports seem to be active; that is to say, none of the devices respond, including the mouse and keyboard! Is there a way that I can activate the USB ports?
    CANCEL - sorry, after rebooting (a couple of times) the usbs became active!
  6. Posts : 1
    Windows 7 Ulimate x32
       #35
    USB Driver Problems
    I am having trouble with my laptop (HP Compaq 6715b) USB ports as I have followed each step by pooch about three to four times. I have searched Google and Youtube but no luck except this thread.
    Before having this problem, my USB ports were working fine about five (5) to eight (8) days ago. These ports cannot be dead as I have tested an old USB stick (to create the new INFCACHE.1 file when following pooch's steps) and my USB mouse and keyboard. Both work in all four (4) USB ports and no errors.
    Once I put in the devices that I need for data and transferring data to is - Seagate External HDD which is brand new bought just before Christmas 2012, Samsung smartphone and USB stick. All these devices give me the balloon error "USB Device Not Regonized". Strangely enough the USB stick that I inserted to refresh the INFCACHE.1 file by following all steps given by pooch works.
    Also, these devices that I am trying to get to work, all of these devices work on my PS3 but not on my HP Compaq 6715b laptop.
    If anyone can please help me that would be much appreciated as I need to get data from these devices and also copy data onto other devices for back up.
    Thank you!
    Mexako
  7. Posts : 1
    Windows 7 x64
       #36
    I have solved my USB copy problems on my Asus P8P67 Pro motherboard by updating the BIOS to the latest version.
  8. Posts : 1
    Windows 7 Home Permium, Service Pack 1, 64bit
       #37
    I get stuck at following poing:
    5. Type Administrators in the window with the blinking cursor, Click OK.
    After clicking on OK as you mentioned in point 5 following widows appears.
    it says:
    Can not find an object named "Administrators". Check the accuracy of the selected object types and location, and make sure you typed the object name correctly, or remove this object from the selection.
    ( ) Correct information object and search again
    ( ) Remove "Administrators" selection
    What do I have to do in this window?
    Thank you for your help!
    Hannes
  9. Posts : 1
    Windows 7 Home Premium
       #38
    Thank you SOOO MUCH!
    I've been trying to get my wireless mouse to work for almost a week now. This tutorial finally fixed it along with a few other devices that were giving me issues on the USB front. I can't say enough how much this helps me out, I hate using a touch pad and it's been driving me crazy!
  10. Posts : 1,045
    Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
       #39
    +10
    I Googled for days attempting to fix my wireless mouse stuttering. This fix made a 99% improvement.
