Windows 7: USB Driver - General Fix for Problems
General Fix for USB Driver Problems
Published by pooch
27 May 2011
I recommend using a wired mouse and keyboard, removing all USB devices and in the section where it says Uninstall all the faded entries. take that as reading uninstall everything USB, if you cannot get hold of a wired mouse then you will have to follow the tutorial as written.
After going through this tutorial You may need to reinstall some USB device drivers!!
After a USB device is installed and then removed Windows hides the driver, this first part makes all hidden drivers visible.
1. Unplug all USB devices except mouse and keyboard.
2. Click on Start orb, Type Advanced System settings in the search box and Click on View Advanced System Settings to go there.
3. Click on Advanced tab, Click on Environment Variables.
4. Under the window "System variables" Click on New.
5. Type devmgr_show_nonpresent_devices as the variable name and type 1 as the value.
6. Click OK 3 times to close the windows.
7. Click on Start orb, Type Device Manager in the search box and Click on Device Manager in the list to go there.
8. Click on View, then Show hidden devices.
9. You will now notice that you have a list of USB devices and that some lines appear to be faded. Uninstall all the faded entries.
The INFCACHE.1 file is used to store information about USB drivers, the information in this file may have become corrupted and may cause windows to load the wrong driver or cause a driver not found message to be generated.
Deleting this file will force windows to generate a new INFCACHE.1 file.
1. Right Click on Start orb and Click on Open Windows Explorer.
2. Select Computer in the navigation pane, and search for INFCACHE.1
3. Right Click on the file INFCACHE.1 (if you have more instances of Windows installed only do this for INFCACHE.1 C:\Windows\System32\Driver Store)
4. Click on Properties, Click on Security tab, Click on Edit, Click on Add.
5. Type Administrators in the window with the blinking cursor, Click OK.
6. Delete the INFCACHE.1 file.
7. Connect a USB device, but not the one you were having trouble with this will make a new INFCACHE.1
8. New Start the PC and try your device again.
NOTE... It may, in a few cases be necessary to go through this Tutorial two or even three times to get this to work.
07 Jun 2011   #1
CAGW
64 Bit Windows 7 Home Premium (SP1)
Hi there, thanks for the tutorial.
I've been having some BSOD probs (accompanied by the message 'BUGCODE_USB_DRIVER'), and I was directed here by another forum user.
However, I couldn't follow you tutorial entirely. Step 9 of the first part says 'Now uninstall all USB devices.' Does this mean I should uninstall everything in the device list (and the sub-lists) that plugs in to my usb ports?
also, step 6 of part 2 says 'Delete the INFCACHE.1 file.' Even after following your previous instructions, the computer still tells me I need special permission to do this - and won't allow me to delete the file.
If you could fill in the blanks for me on this one I would be so grateful!
08 Jun 2011   #2
pooch
Hello CAGW Welcome to the forum,
Before looking at my answer I would advise you to make sure that all drivers on your PC are up to date I have heard of this problem being caused by the Nvidia Graphic driver conflicting with old USB device drivers.
Yes you should uninstall everything, bear in mind that some USB drivers may not be included in Windows and may need to be reinstalled afterwards ie Printer Drivers or in my case I have Renesas USB3 drivers installed.
Are you absolutely sure you have followed the Tutorial with the Infcache.1?? Have a look here; Take Ownership Shortcut Take good heed of the warnings!!
08 Jun 2011   #3
CAGW
hi pooch
thanks for the advice.
i used the 'take ownership' programme to delete the INFCACHE.1 file.
ive also updated all my drivers - and there were a few that needed updating.
i haven't deleted the usb devices yet (i'm short on time!) but thanks for your response on that too.
bearing in mind some of my drivers needed updating, would it be best to wait to see if bsod strikes again before deleting the usb devices?
thanks!
08 Jun 2011   #4
pooch
The tutorial should be done in one go and in order lol or it cannot work and may possibly cause you problems.
Insert a USB device to make a new infcache.
Wait to see if you get any more problems, if yes, go through the tutorial again, completely!!
I hope this helps you and that your problem gets sorted
29 Jun 2011   #5
bens888
win 7 Home Prm x64
solution fo 'BUGCODE_USB_DRIVER' bsod
bsd
for those of you who are having issues with the 'BUGCODE_USB_DRIVER' BSOD after installing SP1 from the exe installer (not the dvd iso sp1 installer, or slipstreamed), here is the solution:
Binary files in some USB drivers are not updated after you install Windows 7 SP1 or Windows Server 2008 R2 SP1
the article suggests getting the fix from http://update.microsoft.com/. For offline installers of the fix, check the above mentioned article.
found it here (not needed, just for reference):
The Windows 7 SP1 USB Driver Bug (what it is and how to fix it)
18 Jul 2011   #6
darkhorse
Windows 7 Ultimate
Hi.
When I came to the most last go tru, where to delete the infcache.1 file, I cannot do it due to priveliges. Ho to solve this ?.
18 Jul 2011   #7
pooch
Quote   Quote: Originally Posted by darkhorse View Post
Hi.
Look at the post directly under the tutorial
18 Jul 2011   #8
bens888
win 7 Home Prm x64
hi pooch,
do you mind including or linking the solution i posted for the 'BUGCODE_USB_DRIVER' BSOD in your post? it's probably the correct solution for CAGW's problem.
i assume this specific BSOD will be fairly popular the next few months, because it's related to win 7 sp1 installation.
thanks
19 Jul 2011   #9
darkhorse
Windows 7 Ultimate
Quote   Quote: Originally Posted by pooch View Post
Hi.
Got it, thank you
General HomeGroup problems
I haven't been much into network file sharing, printer, etc, but I recently looked at my networking window and realized I can't create a HomeGroup or even view the network map (I believe the two problems are related). 1. A while ago, I removed the HomeGroup button from the navigation panel and...
Network & Sharing
Installations Problems and General Questions
I am trying to set up a number of computers with either 7 Professional or 8.1 for some family members. I don't know whether to advise them to stick with 7 and wait for 10 or go to 8.1 at this time. Any recommendations as to what i should do for them? I have noted that application Data in my...
Installation & Setup
Anybody have problems dual booting or with partitions in general
i am dual booting 7 64 bit and ubuntu linux i was wondering if anyone has any issues with this type of setup or just with partitions in general
General Discussion
General Help with a few problems.
Hello guys, Im new here and have found your lovely community to be really helpfull but Im still stuck on a handfull of problems with My Windows 7 run PC. If anyone could try and help run me through the following Id be very greatfull. But please bare with me as Im not 100% literate with PC's...
General Discussion
Help - RAM Diagnostic Tool and General Win7 Problems
I wasn't sure whether to put this in the hardware forum so forgive me and please move if appropriate! I purchased 4GB of RAm a few mnths ago and also got a copy of Vista HP64. From the get go I had all sort of issues in Vista - games would not run, the OS seemed to crash a lot, would get...
General Discussion
