Sticky Notes - Backup and Restore
Page 1 of 5 123 ... LastLast
    How to Backup and Restore Sticky Notes in Windows 7 and Windows 8
    Sticky Notes allows you to type and leave a Post-it type note on your desktop until deleted.
    Sticky Notes is not available in the Windows 7 Starter and Home Basic editions.
    This tutorial will show you how to backup and restore your Sticky Notes in Windows 7, Windows 8, and Windows 10 version 1511 and earlier.
    EXAMPLE: Sticky Notes
    OPTION ONE
    To Back Up Sticky Notes
    1. Open Windows Explorer (Windows 7) or File Explorer (Windows 8), and copy and paste the location below into the address bar, and press Enter.
    %AppData%\Microsoft\Sticky Notes
    2. Save a copy of the StickyNotes.snt file to where you like as a backup of it. (see screenshot below)
    NOTE: This file is your backup of the current Sticky Notes on your desktop.
    OPTION TWO
    To Restore Sticky Notes
    1. Delete all Sticky Notes you currently have on the Desktop if any.
    NOTE: If you do not, then the backed up StickyNotes.snt file from Option One will not be able to replace the other one in step 4 below.
    2. In Windows Explorer (Windows 7) or File Explorer (Windows 8), navigate to where you saved the backed up StickyNotes.snt file at, right click or press and hold on the StickyNotes.snt file and click/tap on Copy.
    3. In Windows Explorer (Windows 7) or File Explorer (Windows 8), and copy and paste the location below into the address bar, and press Enter.
    4. Right click or press and hold on an empty area in the "Sticky Notes" folder, and click/tap on Paste. (see screenshot below)
    5. Click/tap on Copy and Replace. (see screenshot below)
    6. Press the Windows + R keys to open the Run dialog, type stikynot, and press Enter.
    7. Your Sticky Notes included in the backup from OPTION ONE have now been restored.
  1. Posts : 3,612
    nice so in theory i can save all my notes? example: back up at the end of every month and i can file them as jan, feb, march and so forth. at the end of the year i would have 12 back up files corresponding to a particular month of the year.
  2. Posts : 72,043
    Hello Brian,
    Yes, you sure could. :)
  3. Posts : 3,612
    i use a program called ClipCube http://goo.gl/lYU6k to save copied links etc from windows built in clipboard but this function with the sticky notes will be very handy to :)
  4. Posts : 72,043
    ClipCube is a neat little program there.
  5. Posts : 3,612
    yeah its ok brink dont no if its been posted on the free programs thread? its wroth a mention there im sure the other forum users would be interested in it, comes in handy sitting in the tray it runs ok i have had no issues with it :)
  6. Posts : 64
    Windows 7 Professional 64bit
    Awesome! Thanks so much, I was doing a re-install and didn't want to have to copy and paste all my notes into work.
  7. Posts : 72,043
    You're most welcome Tommy, and welcome to Seven Forums. :)
  8. Posts : 43
    +1
    Great tip! Thanks :)
    I'll make a batch file to automate this and put the backup in my Dropbox at the start of everyday.
    That way even if my laptop crashes I won't lose more than a day's worth of sticky notes
  9. Posts : 72,043
    You're welcome James. :)
