DVD ISO build Method by Microsoft
Page 2 of 2 FirstFirst 12
  1. Posts : 6,305
    Brink said:
    Very nice SIW2. :)
    +1
    I do believe it's almost the same as Bootable ISO - Create from an Older ISO
  2. Posts : 72,036
    LOL, just a bit.
  3. Posts : 16,149
    7 X64
       #12
    Thanks Shawn and Shark,
    There are a couple of big differences :
    1. You don't need the paid version of PowerIso ( well worth it imo), or UltraIso, etc - whose main purpose is to edit existing iso files in an automated process.
    Img Burn is free.
    2. You don't need to have a dvd or iso already - you can select ETFSBOOT.COM as the bootimage - that is already in the windows installation files..
    3. You do need to set it up manually as described. If you attempt it with many 3rd party burning apps. - it won't work. Ashampoo Burning Studio warned the bootimg needed to be made into the iso file system - which gave a clue as to what the problem may be. Fortunately ImgBurn allows a great deal of manual configuration.
    4. However, if you have an .iso already, ImgBurn can also be used as a free alternative to the method in
    I have updated my earlier post to clarify that.
    Shawn: Couldn't you just use a program like ImgBurn to do the same thing much easier, or am I missing something again?
    While it can be done with ImgBurn using just the Windows installation files - I'm not sure it is easier than using cdimage.exe, or oscdimg.exe.
    I have updated my original oscdimg post to the minimum command/switches needed , and listed others as optional.
    Hope it makes sense.:)
    Shawn - I'm glad you brought it up - I had never really looked at ImgBurn before.
      My Computers
  4. Posts : 627
    Windows 7 7600.16384 x64
    Good job, after playing with it, I did see the part to make the disk bootable in IMGBurn
