Computer Management - Add to Desktop Context Menu
    How to Add or Remove "Computer Management" to Desktop Context Menu
    This tutorial will allow you to add or remove Computer Management from the desktop context menu for all users in Vista, Windows 7, and Windows 8.
    You must be logged in as an administrator to be able to add or remove this shortcut from the desktop context menu.
    EXAMPLE: Desktop Context Menu and Computer Management
    Here's How:
    1. To Add "Computer Management" to Desktop Context Menu
    Add_Computer_Management_to_Desktop_Context_Menu.reg
    B) Go to step 3.
    2. To Remove "Computer Management" from Desktop Context Menu
    Remove_Computer_Management_from_Desktop_Context_Menu.reg
    3. Save the .reg file to your desktop.
    4. Double click/tap on the .reg file to merge it.
    5. If prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve the merge.
    6. When finished, you can delete the downloaded .reg file if you like.
    7. Right click on your desktop to see the change.
  1. Posts : 1
    11
    nice and thanks
