Windows 7: Computer Management - Add to Desktop Context Menu
How to Add or Remove "Computer Management" to Desktop Context Menu
Published by Brink
24 Jun 2011
information   Information
This tutorial will allow you to add or remove Computer Management from the desktop context menu for all users in Vista, Windows 7, and Windows 8.
You must be logged in as an administrator to be able to add or remove this shortcut from the desktop context menu.
EXAMPLE: Desktop Context Menu and Computer Management
Here's How:
1. To Add "Computer Management" to Desktop Context Menu
Add_Computer_Management_to_Desktop_Context_Menu.reg
download
B) Go to step 3.
2. To Remove "Computer Management" from Desktop Context Menu
Remove_Computer_Management_from_Desktop_Context_Menu.reg
download
3. Save the .reg file to your desktop.
4. Double click/tap on the .reg file to merge it.
5. If prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve the merge.
6. When finished, you can delete the downloaded .reg file if you like.
7. Right click on your desktop to see the change.
Lock Computer and Turn Off Monitor - Add to Desktop Context Menu
How to Add "Lock Computer and Turn Off Monitor" to the Context Menu in Windows This tutorial will show you how to add Lock Computer and Turn Off Monitor to the desktop context menu in Windows 7 and Windows 8. When used by a user, it will lock the computer and turn off the display...
Tutorials
Lock Computer - Add to Desktop Context Menu
How to Add "Lock Computer" to the Desktop Context Menu in Windows 7 This will show you how to add or remove Lock Computer to the desktop context menu in Vista and Windows 7. EXAMPLE: Lock Computer in Desktop Context Menu Here's How:
Tutorials
Cascading "My Computer" menu in desktop context menu
I recently switched from XP to Win7 x64. I've used Stardock RightClick for years to make a cascading "My Computer" menu in the desktop context menu. This is a very handy way to browse files and folders. I found the tutorial @sevenforums to make a shortcut to "My Computer", but I really like to make...
Customization
Add Computer Management to Desktop Context Menu
@ Mark: Hello. Nice to meet you. I know this is an old thread, but I wanted to keep my question based on your initial post or instruction. I stumbled upon this thread in my searching for this very issue. THANK YOU for your dedication and work with this issue and your solution!!! My...
Customization
Computer - Add or Remove from Desktop Context Menu
How to Add or Remove "Computer" Desktop Context Menu in Windows 7 and Windows 8 This tutorial will show you how to add or remove Computer from the desktop right click context menu for all users in Windows 7 and Windows 8. While, you will only be able to add or remove the "Computer" desktop...
Tutorials
Twitter Facebook
