#20
Very nice Brink and very handy. :)
As per usual, I am much obliged.
Well done, Shawn.
Hmm on any file if I choose Permanently Delete a window opens asking what program I want to use to open the file.
Did you put this SDelete in your system32 folder?
A) Download SDelete, save it to your Desktop, open the downloaded SDelete.zip file, extract (drag and drop) the sdelete.exe to your desktop.B) Right click on the extracted sdelete.exe file, click on Properties, General tab, and on the Unblock button.
NOTE: If you do not have a Unblock button under the General tab, then the shortcut is already unblocked and you can continue on to step 1C.C) Copy and paste the unblocked sdelete.exe file into the C:\Windows\System32 folder, then click on Continue and Yes to approve copying it there.
is there anyway to have it remove the folder as well.
i click delete perm on a folder and it just deletes everything in the folder but leaves directory there.
