Permanently Delete - Add to Context Menu
Page 5 of 10 FirstFirst ... 34567 ... LastLast
  1. Posts : 52
    Yes I know about more when 15 items selected, no I just trying with 2-3 files.
    %1 not working even with single file or folder. %2 works with single, but no success with multiple.
  2. Posts : 72,050
       #41
    I'm afraid that I'm not sure why it's not working for you with multiple items selected with it being used in Classic Shell instead.
  3. Posts : 52
    %2 is the problem, I think its for single file only.
  4. Posts : 72,050
       #43
    I tested %2 using the method in the tutorial, and it wouldn't work at all. Only %1 worked using that method.
    I'm not sure what would work with Classic Shell though.
  5. Posts : 52
    %1 yes it works from context menu. %1 with Classic Shell as I mentioned before not working, only %2, but only with single file
  6. Posts : 21,004
       #45
    So if I have it right Shawn I can delete permanently everything I pick down to just having the OS left on the drive? and I can use The Bare Foot Kid's tut to delete the whole drive?
    I have a few old drives that I want to scrub up and this looks like what I want - but I just to make sure.
  7. Posts : 72,050
       #46
    Hello John,
    This is mostly for permanently deleting individual files. If you wanted to delete everything on a HDD, then using the "clean" command below would be a faster way to wipe it. :)
  8. Posts : 21,004
       #47
    Thanks Shawn up with the goods again
  9. Posts : 72,050
       #48
    You're most welcome. :)
  10. Posts : 7
    This is pretty excellent. I was still pretty new to batch files, before reading this, I'm kind of stoked that I have a way to put my own commands into the context menu now. Did not know u could do that with registry =)
    Is there any way to have it prompt user for something like "Are you sure you want to delete?"
    Would it be possible to put an in-line prompt on the command in the registry? Like, I know this is not real syntax, 'Prompt "Are you sure?" | if yes do "sdelete.exe /p 3 /s %1"' ?? Did that make any sense? Can you do a prompt and a command all in the same line?
    Or what if i put that sdelete.exe command into a batch script with the prompt, and the registry command could just run the batch file? How would that look?
