#20
Out of curiousity - why do you favour DBAN instead of Windows's native 'clean all' command for HDDs?
Never heard of 'Parted Magic'. Must be one out of many 3rd party tools. So again - how is doing a secure erase in Parted Magic any different than Windows's native 'clean all' command? 'Clean all' is secure erase so basically they are the same thing. Not that you said they aren't but I'm just asking.
I used DBAN once long ago but basically it does secure erase with various algorithms and passes. So AGAIN - if DBAN performs a secure erase and you recommend 'secure erase in Parted Magic' then it's the same thing - secure erase/secure delete/wipe etc. Only difference I imagine is that DBAN does more passes or the wiping algorithms require more writes versus the 'secure erase in Parted Magic' (which you recommend) which I guess is simply 1 pass of secure erase. Pls, explain what you recommend, I'm curious. :)
Have used TrueCrypt but never knew about Evil maid. What's that?
