Windows 7: Secure Erase / Wipe : Definition and Methods
22 Jul 2018   #30
soewhaty
Win 7 x64
Quote   Quote: Originally Posted by joe7dust View Post
" I have used Ccleaner's wipe options and then ran Recuva and all the files were still able to be recovered."
Well if everything is to be believed in this thread then neither CCleaner, cleanall, or dban 1 pass Simple are effective. And I still never got a response on whether residual magnetic recovery is possible after a zero fill using a SATA connection and recovery software.
You managed to recover data after 'clean all' via CMD?
22 Jul 2018   #31
joe7dust
Windows 7 Ultimate 64-bit
Quote   Quote: Originally Posted by soewhaty View Post
Not I, but I think someone earlier in the thread had said that.
22 Jul 2018   #32
soewhaty
Win 7 x64
That was F22 Simpilot's response to your questions - 'What data recovery software makes ccleaner wipe obsolete?'
So, unless we equate ccleaner's wipe to a 'clean all' then we can't say that it is psbl to recover data after a 'clean all'.
22 Jul 2018   #33
joe7dust
If secure wipe in ccleaner doesn't do it I would consider that a bug.
Worse than a bug, perhaps more like a Vulnerability of the open secret type.
23 Jul 2018   #34
soewhaty
Win 7 x64
If there's a native way to do this in Windows, which there is (via clean all in CMD), then I'd much rather stick to that than to CCleaner or any third party tool for that manner.
But I'm still curious to hear F22 Simpilot's views on what I asked him lastly. Hope he understands I meant it well in the name of discussion ...
23 Jul 2018   #35
joe7dust
Quote   Quote: Originally Posted by F22 Simpilot View Post
To answer the questions here.
The clean command as I understand it just zeros the HDD. There is no data written over the current data at all, making recovery very easy. DBAN on the other hand, while very slow will overwrite the data many times making data recovery much more harder. Like I said, you don't want to use DBAN on a flash-based medium as it can only handle so many writes. With a SSD you want to use Parted Magic's secure erase option. Secure Erase - Powerful, easy to use, and inexpensive.
Evil Maid: The Invisible Things Lab's blog: Evil Maid goes after TrueCrypt!
If all this is fact then clean is the same effectively as 1 pass dban. And CCleaner needs to patch this vulnerability of a bullshit wipe implementation.
23 Jul 2018   #36
soewhaty
Win 7 x64
Again ... distinguish carefully between 'clean' and 'clean all' ... they are not the same thing.
What you are referring to is 'clean all' and from what became evident from the discussion here - dban overwrites a drives sectors with new data, instead of only zeroing those sectors (which is seemingly what 'clean all' does).
secure erase SSD
I use pretty often Acronis - recovery. Do i have to secure erase the SSD from time to time ? Would that help ? Thank you
Performance & Maintenance
Additional Secure Erase / Wipe Information
After you have copied out or made back-ups of the data you need to save to external media and want to do a complete wipe secure erase of the entire Hard Disk Drive / Solid State Drive, have a look at Step One of the Optimize tutorial below then boot the Windows installation media to start the...
Installation & Setup
Secure erase on a ssd
How do you do a secure erase on a ssd and will this remove everything?.
Hardware & Devices
Some Methods To Best Secure Your PC
Here are some ideas to secure your PC. Some are well known, others are not, but just as helpful Gizmo's Guide to Securing Your PC
System Security
Secure Erase / Wipe : Definition and Methods - Tutorial
This one has been in the works for a while and I just got it finished, though it may need some fine-tuning; if anyone has some ideas, please post at the tutorial, thanks! :) Secure Erase / Wipe : Definition and Methods
Chillout Room
